IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Passenger door's dead
Old Aug 5, 2021 | 05:35 AM
jupi1985's Avatar
jupi1985
Default Passenger door's dead
Hi!
Please help. The rear passenger door of my 2jzge swapped Lexus IS200 00' is dead. By that I mean that both the lock and window do not work. Took everything apart. Checked the door's wiring - all wires good. Checked both door lock motor and window actuator - both work if connected to a independent 12v battery, however once everything is put back together, DEAD. All the other doors and windows work fine, both individually, and from the driver's door. I've heard that the problem can lie in the MPX Body control unit being faulty? Or something else?
Thanks! Lexus FTW!
Old Aug 5, 2021 | 10:22 AM
2001SolarY's Avatar
2001SolarY
Active Streak: 30 Days
Not likely the MPX. Check the harness.
Old Aug 6, 2021 | 06:23 AM
jupi1985's Avatar
jupi1985
You mean the wires that go to the door? The ones in the door itself are fine, checked those.
Old Aug 6, 2021 | 10:33 AM
2001SolarY's Avatar
2001SolarY
So the wires have power? Also the signals from the drivers master switch passes signals to it.
cody0r
Jun 30, 2021 01:08 PM
laoster
RX - 1st Gen (1999-2003)
Oct 22, 2019 09:05 AM
mekelly
Apr 9, 2015 10:44 AM
gizmatix
Jul 16, 2012 10:52 AM
tim5055
Oct 28, 2009 02:49 PM
