Torque specs
Hello. My car is a Lexus IS 300 2003. Does anyone know the torque lb on the 2 bolts above the dual cams? I'm not sure if they are 10 mm but I heard it it should be 10 lbs. Does not sound it correct and just want to make sure. I am replacing the dual cam seals, crank seal, valve cover gaskets, spark plugs, coils, spark plug wires. It's been a journey to say the least. Thanks in advance.
JT
JT
