Torque spec help - valve cover bolts
Old Jun 10, 2015 | 04:11 PM
volson's Avatar
volson
Default Torque spec help - valve cover bolts
Hey guys,
I thought I saw it in a thread somewhere but I can't find it while searching. I finished the valve cover gasket, plugs, plug tube seals, pcv, pcv grommet on the drivers side. I am ready to fire it up once I torque up the valve cover bolts.
Old Jun 10, 2015 | 04:49 PM
Tom57's Avatar
Tom57
Originally Posted by volson
Hey guys,
Valve cover torque: 69 in-lbs which about 6 ft.-lbs. Your torque wrench likely doesn't go that low. Use a 1/4" drive socket wrench. Use some gasket compound. Start in the middle and work your way alternating each side to each valve cover end. Snug is all you need.
Old Jun 10, 2015 | 04:55 PM
volson's Avatar
volson
Thanks! I got an inch lb torque wrench when I got this car because I am trying to do everything right.
Old Dec 22, 2015 | 10:47 AM
cyclehead's Avatar
cyclehead
The torque spec I looked up showed 53 in-lbs for the "engine cover x cylinder head". I presume that's Japanese translation for Valve cover.
Old Dec 22, 2015 | 05:55 PM
StanVanDam's Avatar
StanVanDam
2002-2004 service manuals show 53 in-lbs
murphysf
RX - 1st Gen (1999-2003)
May 17, 2019 10:26 AM
LexBrett
Apr 2, 2015 01:27 PM
Bankswood
Dec 9, 2014 10:46 AM
Lukas99GS
Jan 11, 2014 05:23 AM
ivnnln
Nov 23, 2010 08:54 PM
