IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Stutter on acceleration
Old Jan 9, 2019 | 04:30 PM
CurpzGreen's Avatar
CurpzGreen
Default Stutter on acceleration
I picked up a 2002 is300 for $1500 it needs a lot of tlc.
i replaced cool packs and spark plugs also installed a new fuel filter. But it still is having a stutter issue. It only stutters from low rpm to about 4-5k then it runs perfect. I can’t figure it out and would love some advice. ( also I checked the injectors and everything seems to be working fine)
Old Jan 22, 2019 | 06:18 PM
SteadyMobb's Avatar
SteadyMobb
Have you cleaned your maf sensor?
Old Jan 23, 2019 | 05:34 AM
CurpzGreen's Avatar
CurpzGreen
I bought a new one.
Old Jan 23, 2019 | 05:35 AM
CurpzGreen's Avatar
CurpzGreen
Originally Posted by CurpzGreen
I bought a new one.
still studdering it’s only on low rpm man. High rpm it runs great like over 5k there’s no studdering I can mash the pedal whenever.
Old Aug 29, 2019 | 01:40 PM
Stuis01's Avatar
Stuis01
Default Tb
Clean throttle body
Make throttle cable tighter
Check all fluids
Fix leaks
Old Aug 31, 2019 | 10:07 PM
zKabi's Avatar
zKabi
I had this same issue a few months ago. Eventually it started backfiring throwing codes, P0301 and later P0300. I replaced the valve cover gasket, intake plenum gasket, spark plugs, ignition coils, and spark plug wires. All OEM quality. Car ran great there after.
lucasLS400
12
Mar 12, 2019 08:00 AM
Atlsdad
Jul 15, 2018 05:05 AM
Luxurious
May 28, 2018 07:05 PM
nyjah
Apr 11, 2018 06:02 PM
Moarpower
Nov 12, 2017 07:41 AM
