Car won’t accelerate quick from dead stop
Old Apr 9, 2018 | 04:13 PM
nyjah's Avatar
nyjah
Default Car won’t accelerate quick from dead stop
I have a 2001 Lexus gs300 and when i come to a complete stop and step on the gas the car acts sluggish and doesn’t accelerate normal until i reach around 25 mph. I replaced the spark plugs, ignition wires & ignition coils and i still have the same problem 😒 i took it to a couple shops and they don’t know what’s wrong with the car and told me to take it to a Lexus dealership but i refuse to since i don’t have the cash to pay for it. I cleaned the throttle body with spray for it but i didn’t clean inside the MAF yet. It idles great in park but as soon as i put it in drive the rpms drop to around 750 and shakes slightly... what should i do?
Old Apr 9, 2018 | 06:21 PM
Mr Jokster's Avatar
Mr Jokster
You're probably shocking the poor car with a ton of air when you just told it to stop then stomping on your accelerator. Anywho... could definitely be the MAF, could be a TPS issue could be a lack of fuel i.e. fuel filter, injectors etc. You should keep doing it and see if you can mess something up or strike a code or something. Or, you can just not floor it from a quick stop. Just a suggestion.
Old Apr 10, 2018 | 09:56 AM
kevin3344's Avatar
kevin3344
You can always have the dealer do a diagnostic and buy the parts yourself. It will probably cost around $125. Or better yet find an Indy that knows the 2GS. Most of us on CL have someone who knows the vehicle but is much, much cheaper than the dealer.
Before I found my Indy I had an issue with my car stalling that I thought was going to cost an arm and a leg at the dealer. They diagnosed it inside of an hour as a cracked vacuum hose - didn’t even charge me to replace it. So the dealer is not always the worst place to take your car. Expensive sometimes yes but I would rather know that not.
Old Apr 10, 2018 | 12:17 PM
Blaze876's Avatar
Blaze876
Check if the air intake where the baffle is, if it is cracked on the bottom.
Old Apr 10, 2018 | 12:48 PM
Tuanville's Avatar
Tuanville
Check to see if your “snow” option is on. It’ll make your car sluggish. My snow button light doesn’t light up but when I hit it it still work.
Old Apr 10, 2018 | 04:53 PM
MikeFig82's Avatar
MikeFig82
MAF SENSOR, and inspect your air filter. Might as well get a new one if it has more then 10k miles on it. Purolator One is a good alternative to the OEM.
Old Apr 10, 2018 | 05:03 PM
Letsride's Avatar
Letsride
Give us some basic info and not have us guess......Mileage, any codes....etc?
Old Apr 11, 2018 | 06:02 PM
nyjah's Avatar
nyjah
Default fixed the problem
after a whole lot of plug and play i finally found something that made the car act the ways it’s been acting.. bought a new MAF sensor and the car works like it’s brand new 😄 thanks everyone for the help 🤟🏽
eozgo
Nov 5, 2013 05:28 AM
danielaj
Jun 5, 2013 08:30 PM
IS_250
Feb 28, 2011 08:51 PM
stokdd
Nov 16, 2006 05:35 PM
99LS400BLK
Jun 13, 2006 07:26 PM
