IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
is200 shuts off while driving
Old Oct 15, 2018 | 08:12 AM
Lelio's Avatar
Lelio
Default is200 shuts off while driving
I have a 1999 lexus is200 and while i`m driving the engine light appear then the engine dies. after a few minutes sometimes the car starts again the engine light dissapear by itself. I have change coils and spark plugs the fuel pump is ok also. On computer appears ignition fail but i can`t find what`s the problem. I apreciatte if anyone can help me. many toyota/lexus have this problem and i can`t find any solutions. I`m sorry for my bad english
Old Nov 17, 2018 | 06:12 AM
mickyd481's Avatar
mickyd481
hello there
you might need to replace your ignition unit as it becomes worn out, I've had it before on a customers car
it loses connection between the ignition switch and relay fuse box and cuts out.
hope this helps
Old Nov 20, 2018 | 05:58 AM
gabygarci's Avatar
gabygarci
The same thing is happening to me with RX350, it is in the local lexus dealer and they dont know what it is!
Old Nov 20, 2018 | 06:17 AM
Ajowhan's Avatar
Ajowhan
You should not be sorry for your bad english. I applaud you for learning and using another language.
Old Nov 20, 2018 | 05:59 PM
daddystop's Avatar
daddystop
This is in the wrong section it looks like, this is for the first gen is300's 2001-2005. You may have more luck if you post in the proper spot, maybe the mods will help move your thread over there. I wish I had some ideas for you on the actual problem you're having.
I think it would help to know which sensors can cause the car to shut off completely. I would check your battery cables and alternator because I know those things not working properly or having an intermittent connection can cause the issue like you're seeing. It doesn't explain why it would work after shutting the car off for a few minutes but you might just be getting into this lucky situation where it cools off and connects again. Hot electronics expand and contract as they cool so..... I know that's far fetched but I've had my car do some stupid intermittent stuff when the battery cables weren't in good condition.
SushiSalad
Apr 7, 2019 05:19 PM
morten
Nov 26, 2018 08:33 AM
Lelio
Oct 15, 2018 01:12 PM
mikegbuff
Jan 25, 2013 03:46 PM
rbluemer
Jul 18, 2006 03:58 PM
