IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Check engine light
Old Feb 15, 2018 | 03:26 PM
Mann7374's Avatar
Mann7374
Angry Check engine light
Hi Guys,
I recently purchased an 06 GS 300 and found that the seller was less than honest. However, i have since fixed a number of issues. The check engine and VSC light is on. The car drives fine, the codes indicate failing cat converters. Anyone had a similar experience or solution apart from spending$3,000.00?
Old Feb 24, 2018 | 08:54 PM
toneekay's Avatar
toneekay
You can get an O2 simulator which will bypass the post-cat sensor. So far in my searches, there have been "tokensolutions" and "klong" O2 simulators, however I'm it seems like these were individuals that used to be active here on the boards that used to make them for the community. I'm not sure if you can still reach out to them, or other individuals that'll make them for you, but if you are pretty adept with electricals, then you can make your own (link below):
http://www.freeinfosociety.com/elect...ew.php?id=2091
TFly23
Oct 14, 2013 08:35 PM
VIP12
Aug 24, 2009 01:05 AM
AKA K2
RX - 1st Gen (1999-2003)
Aug 17, 2009 08:36 PM
johnny1
Jul 26, 2006 04:47 AM
Jasoneo5
Mar 6, 2004 02:55 PM
