IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Can't open tail lights....help
Old May 4, 2003 | 04:28 PM
siniquezu's Avatar
siniquezu
Default Can't open tail lights....help
I was trying to open my friend's IS tail lights using the 400 degree oven method. I've open my SC headlights before so I'm fairly aware of how to do it. In addition, it's easier because the glue is visible surrounding the SC headlight lenses. The IS tail lights on the other hand don't have a clear "weak" glue point. I can't see the glue surround the lens. I tried prying at the corners and wedging the lens out but it won't budge. Any help guys? Thanks.
Old May 9, 2003 | 09:54 PM
siniquezu's Avatar
siniquezu
Anyone?
Old May 13, 2003 | 10:51 PM
YoNadz's Avatar
YoNadz
why are you trying to get into them??
Old May 14, 2003 | 02:18 AM
rominl's Avatar
rominl
exclusive matchup
some people want to take out the chrome part and black out the whole thing.
i guess the is300 tails are much better designed, couple of guys tried to bake it already but never work... i guess dremel will work, but i wouldn't try
Old May 15, 2003 | 09:39 AM
baadhabit's Avatar
baadhabit
Default Re: Can't open tail lights....help
from what i understand the IS300 taillights are not held together with the same glue as the headlights. you would have to cut through the plastic to take them apart.
i borrowed this from is300.net
quote LCA575
You can't put them in the oven like headlamps beacuse they melt easily and a heat gun dosen't work because the glue is too strong. You need to cut them open with a heat knife. I had to fabricate a curved thin blade to cut the lights without cracking the lens. Then if you are sucessful with getting the lights open you need to prep, prime, paint, reassemble and seal the lights. Its a time consuming process but when you consider the cost of JDM painted lights I guess its worth it.
Old May 15, 2003 | 04:48 PM
siniquezu's Avatar
siniquezu
I caught that on the IS board but the guy didn't really explain what he meant by a heat knife. I tried asking the local Home Depot if they had one but they didn't. Do I just heat a knife and start cutting?
Old May 20, 2003 | 02:32 AM
oh-dawg's Avatar
oh-dawg
Go to a hobby store.. they'll know what a "heat knife" is..
nimit1234
Jun 5, 2006 05:22 AM
LexDiamond
12
Jul 15, 2003 11:50 PM
The_Hitman
May 19, 2003 11:06 AM
siniquezu
Lighting
May 8, 2003 12:44 AM
enginyr
May 14, 2002 02:31 AM
