IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
vibration while decelerating or speeding
Old Oct 13, 2011 | 10:17 PM
xlex01's Avatar
xlex01
Default vibration while decelerating or speeding
Does anyone know what could be causing my 01 IS300 vibrate when i let off the gas pedal when im doing about 65 or faster. Also when im doing about 80 to 100 my car seems to vibrate im wondering if its my tires needing to be rebalanced or is there something common for this issue? fyi i have the stock 17s on it. thanks for your input
Old Oct 13, 2011 | 10:36 PM
rayy117's Avatar
rayy117
mine was like that as well, got wheels and its fine now. But i think it was the balance of the wheel that was off. does it vibrate when u brake? if not then its the wheels/tires/balance of the wheels
Old Oct 13, 2011 | 11:28 PM
doitra's Avatar
doitra
if it is affected while you brake, you want to check your brake and rotors. if it is just while you're driving, i suggest you first go to a shop and ask for them to mount and balance your wheels and get a 4 wheel alignment. if the alignment fails, they'll know why and what to do. if it passes, you should be good to go
Old Oct 14, 2011 | 01:43 AM
xlex01's Avatar
xlex01
yea its not when i brake only when i decelerate at higher speeds as just letting off the pedal and also when im doing around 80 to 100 but yea il take it in and see if that fixes the problem. thanks for the input.
Old Oct 14, 2011 | 05:37 AM
dsouthmia0's Avatar
dsouthmia0
check motor mounts aswell even though these dont go to often
Old Oct 14, 2011 | 06:41 AM
Zstuddin's Avatar
Zstuddin
you shouldn't be driving that fast anyways, har har har
Old Nov 8, 2011 | 03:31 PM
wil300's Avatar
wil300
any updates i have the same problem thanks
Old Nov 9, 2011 | 09:21 AM
BernieIS's Avatar
BernieIS
There are several possibilities
1. Tires need to be rebalanced
2. Tires are cupped and need to be replaced
3. Warped brake rotors - typically would only notice when braking
4. Potentially bad wheel bearings
5. Possible bad suspension components - tie rod, ends, etc.
ggmonogram
Apr 24, 2018 04:46 PM
oldManTan
Jul 8, 2014 06:13 PM
Globalinx
GX - 1st Gen (2003-2009)
Feb 26, 2013 08:25 PM
Bellex
Jun 1, 2009 09:43 AM
MJMerlina
Oct 1, 2007 10:52 AM
