Annoying Vibration
Old May 29, 2009 | 08:26 AM
Bellex's Avatar
Bellex
Default Annoying Vibration
So I've been dealing with this annoying vibration for a couple of months.
Symptoms:
-Starts around 50 and goes to about 80
-Vibration is exaggerated vigorously turning the wheel side to side at speed
- No bent wheels (2 new wheels from Lexus a month ago -told them to check suspension-they found nothing)
- Alignment is recent and in spec
- Tires have <5000 miles... wear on drivers side edges
-Took to local tire shop yesterday they said my pressure was too low and rotated -and that the suspension has no play.....Still There!
What could this be???
Thanks in advance
Old May 29, 2009 | 08:53 AM
Shunter's Avatar
Shunter
Could be your brake disc's, (rotors), are worn.
Do you get a similar vibration under braking??
Old May 29, 2009 | 08:54 AM
intdiamond's Avatar
intdiamond
Could need better balancing, and/or, if your wheels have or need hubcentric rings and they're either not in the wheel or not seated properly you will get that vibration. If the "Lexus" wheels don't require hubcentric rings, try pulling the wheels off, turn them so they sit on different studs than they're on now, and tighten them back up. If the wheels aren't tightened onto the car perfectly, you will get vibrations, especially at the speeds you're indicating. Our SCs are particularly sensitive to this.... GL.
Old May 29, 2009 | 09:40 AM
lyyca's Avatar
lyyca
Yeah, get ur wheels balanced and maybe take ur car to another alignment shop. I had the same problem before and did all that and everything went smooth.
Old May 29, 2009 | 10:44 AM
jimmer!'s Avatar
jimmer!
when I picked up my 04 I had a real quick and violent vibration. rattled the windshield at speed.
first I went to a tire shop that had a 'road force' balancing machine.
it's very expensive and lots of tire/service place don't have it.
road force balancing is the only way to go.
vast improvement after that.
eventually I went all the way with new wheels and pilot sport a/s conventional tires, with nitrogen.
run flats just aren't appropriate at this stage in their development.
that did it for me. a great ride, not vibration.
hope that helps.
jimmer
Old May 29, 2009 | 03:27 PM
PHXSC's Avatar
PHXSC
Belt separation on one or more of the tires?
Old May 30, 2009 | 10:51 AM
tromly's Avatar
tromly
That's what I think it is too ! Can't be rotors if it occurs when not braking. Good Luck
Old Jun 1, 2009 | 09:28 AM
Bellex's Avatar
Bellex
Hmm - couldn't be the rotors are the rotors/pads are brand new all around (and no vibration when braking)- I guess I will give this roadforce balancing a try... Wheels are OEM Pie Plates. How might belts be separated on new tires??
Old Jun 1, 2009 | 09:43 AM
intdiamond's Avatar
intdiamond
See if the tires are mounted in the wrong rotation direction
Dealerships sometimes forget to mount them in the proper direction.... this can cause noise, vibration, and many times, belt separation. (Check the direction arrow on the side of the tires.)
sarah
Wheels, Tires & Brakes Forum
Jul 22, 2015 11:41 AM
swerve
22
Mar 10, 2012 01:05 PM
daelo74
Jul 13, 2010 12:25 PM
tlegend
RX - 1st Gen (1999-2003)
Feb 4, 2008 03:20 PM
CoreY2K1
Feb 17, 2003 03:59 PM
