IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Sensor lever on the front strut?
Old Jan 27, 2011 | 10:49 AM
Shadowen's Avatar
Shadowen
Default Sensor lever on the front strut?
I saw it there the other day when I had the front wheels off. What is it for. it looks like it reads the travel of the front strut. It's only on the driver's side.
Old Jan 27, 2011 | 11:58 AM
baadhabit's Avatar
baadhabit
post a pic.
only box i can think that sits on the oem strut tower is the ignition box
Old Jan 27, 2011 | 12:05 PM
Justin727's Avatar
Justin727
Its for the headlights. Helps keep them level on the road as the car raises and dips.
Old Jan 27, 2011 | 12:07 PM
Shadowen's Avatar
Shadowen
Originally Posted by baadhabit
post a pic.
It's not in the engine bay, it's like on the control arm I think. I only noticed it and don't remember exactly how it was setup. I'll try to take a picture later.
Old Jan 27, 2011 | 12:08 PM
Justin727's Avatar
Justin727
Its what I said
Old Jan 27, 2011 | 12:44 PM
Shadowen's Avatar
Shadowen
Originally Posted by Justin727
Its what I said
I see, never knew that.
Is there a proper way to aim the headlights? because my Passenger side is lower then my driver side. This isn't a JDM...
Old Jan 27, 2011 | 01:04 PM
Justin727's Avatar
Justin727
I think some people have manually adjusted them but from the factory it has "auto" leveling headlamps.
1 is suppose to be higher than the other. Couldn't remember which side, when it gets dark out I'll look at mine.
Old Jan 27, 2011 | 02:08 PM
Shadowen's Avatar
Shadowen
the light auto adjusts, but if the housing is off, the light won't auto adjust to the correct spot. The driver side should be lower as not to blind oncoming traffic.
Old Jan 27, 2011 | 03:32 PM
Justin727's Avatar
Justin727
Then its something more then the headlight. Car may have been in a wreck. Could be front radiator support assy and or fender.
Joker4096
IS F (2008-2014)
Jun 13, 2016 07:25 AM
UNCJD
14
Oct 19, 2015 09:07 PM
Polkatulk
Suspension and Brakes
Apr 11, 2015 09:48 AM
dcdyd
Mar 31, 2013 03:17 PM
jacksonvp
Dec 27, 2008 11:37 AM
