IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
no heatshield ok?
Old Jul 21, 2010 | 11:58 AM
calboy76's Avatar
calboy76
Exclamation no heatshield ok?
got my K&N, offered $40 and one local shop did it for me today
but they said no room to install heatshield.
is it ok???
Old Jul 21, 2010 | 12:07 PM
sway162's Avatar
sway162
Go back to the shop and tell them to make it work! You need the heat shield. It should fit.
I was under the impression that you need one but maybe not.
Old Jul 21, 2010 | 02:28 PM
Jetfire's Avatar
Jetfire
Royale with cheese
heatshield helps reduce the amount of hot air getting sucked in. but still not as good as a cold air intake or a ram air.
if you don't care about engine power and only care about intake noise, then you don't really need it.
Old Jul 21, 2010 | 05:11 PM
calboy76's Avatar
calboy76
went back to the shop. got it installed
Old Jul 22, 2010 | 05:29 AM
noe1998's Avatar
noe1998
there's a cold air intake for is
Old Jul 26, 2010 | 08:43 AM
slvrboolet's Avatar
slvrboolet
I have no heat shield on my turbo car and its just fine ;-)
Old Jul 26, 2010 | 08:52 AM
Kaydee's Avatar
Kaydee
Hacked CL to become a Mod
^ turbo you won't need it since air will be cooled by the intercooler
Old Jul 26, 2010 | 08:53 AM
06isDriver's Avatar
06isDriver
well sure its fine...but you arent reaching your maximum horsepower potential...especially with the air being compressed like that in a turbo application.
every 11 degree drop in intake temp = ~1% gain back in horsepower
Old Jul 26, 2010 | 08:58 AM
06isDriver's Avatar
06isDriver
it will cool it as much as it can from the temperature it started at....I would assume that if the temp were lower to begin with you would yield lower temps after the intercooler too.
Old Jul 26, 2010 | 09:05 AM
slvrboolet's Avatar
slvrboolet
its tru like when its cooler outside the car runs quicker/faster when there is lots of hot air you can tell its more bogged down.
MrBalistic
Jul 31, 2014 05:56 PM
ArmyGrl88
Performance
Apr 8, 2014 06:33 AM
BiggDatty
Performance
15
Jan 19, 2014 11:54 PM
The1Ghost
Performance
Jun 12, 2011 10:12 AM
Jmai22
Aug 20, 2002 10:01 AM
