IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
o2 sensor issue
Old Aug 11, 2009 | 01:09 PM
PoorMan'sR's Avatar
PoorMan'sR
Default o2 sensor issue
Alright, so to start off i got a P0161 code, i think? anyways it was the furthest back on the exhaust o2 sensor. Picked up the part, go to replace it, everything is going wonderfully, I broke the o2 sensor loose, then once i figured it was going to be coming out from there i unplugged the wire so it wouldn't wrap around the socket.
This is where everything goes wrong, i start to twist the o2 sensor out the rest of the way and it stops, so i use some more force, nothing, get a breaker bar, nothing, get a longer breaker bar, strips it, so i sawed off the end of the o2 and started to drill it out, maybe relieve the pressure on the threads, still didn't work, so i gave up. Took it to midas and they are saying the need to super head it to get it out but it might mess up the threads, in which case i would need a new pipe which apparently has a cat on it and cost 1100 from lexus, anyone have any ideas on what i could possibly do to fix this?
Thanks,
-Matt
Old Aug 11, 2009 | 01:13 PM
Faymester's Avatar
Faymester
well ... um, you're kinda stuck now since the old o2 sensor is stuck in there.
Only thing I could suggest is ... maybe weld a new set of threads into the now large-ish hole where the o2 sensor goes?
On the upside, once you've solved this, the only other thing that can mess with you is the CD stacker
Old Aug 11, 2009 | 01:35 PM
PoorMan'sR's Avatar
PoorMan'sR
haha yea i was thinking welding a new housing onto the pipe, it just seems crazy that the only way to fix it would be to get the new pipe when the person who put the o2 in in the first place didn't use antiseize, i need to find a way to fix this, thanks.
Old Aug 11, 2009 | 09:59 PM
the.wong.k's Avatar
the.wong.k
haha whoever put that o2 sensor clearly forgot to put some dielectric grease on the sensor before screwing it in...fail....
Old Aug 12, 2009 | 04:42 AM
UNOHOO's Avatar
UNOHOO
EPIC FAIL
Old Aug 12, 2009 | 10:45 AM
the.wong.k's Avatar
the.wong.k
haha nice one
Old Aug 12, 2009 | 02:34 PM
RCPnoi's Avatar
RCPnoi
check out the sale section, i always see people parting out rides and you can get the whole manifold from a member
i would sell you mine but i will need it for inspection when i bring it to japan =P
semnosNSX
IS F (2008-2014)
Jun 30, 2025 05:54 PM
coug66
Jun 7, 2019 05:02 PM
jmsmiff
Mar 27, 2013 07:28 PM
Gunnut
Jan 27, 2008 10:35 AM
palaka
RX - 1st Gen (1999-2003)
Aug 20, 2007 07:51 PM
