2jz-gte swap into IS300? Difficulites?
I have a complete Supra TT drivetrain which includes:
GTE bottom end
GTE head
V160 trans
TT driveshaft
supra TT rearend
ecu + harness'
Question i have for you guys is:
Is there any "special" things that need to be done to perform the swap?
1.)-Does the driveshaft need to be customized?
2.)-Will the supra 6spd rear diff fit?
3.) -Will my supra TT brakes fit on the is300?
Any helpful hints from someone who performed the swap would be apreciated.
Thanks!
-brad
GTE bottom end
GTE head
V160 trans
TT driveshaft
supra TT rearend
ecu + harness'
Thanks!
-brad
1. YES
2. YES with modification
3. YES with an adapter for the bracket. +if you are running stock wheels, you need spacers (15mm)
Good Luck to you on this project, as only few venture down this pathway...
