IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Electrical issues?
Old Oct 14, 2004 | 09:36 AM
crystalf's Avatar
crystalf
Unhappy Electrical issues?
Just bought a used IS 300, 2001. 2 weeks ago the dashboard light that signalled one of the tail lights was out came on. But when I checked it, all were working fine. Next time I started up the car, the light was no longer on. A couple of days later, came back on while I was driving. Again, when checked, nothing (and of course the light wasn't on next time I drove)! Last week my passenger-side window wouldn't roll back up for a couple of hours. Then, just like the warning light, next time I started the car back up it rolled right up. Took it into my local Lexus dealer....they checked all the tail light bulbs and the window. They all were fine -which they are FOR NOW! I don't know anything about cars - but everyone I 've told, including a mechanic friend of mine, seems to think there may be a problem with the electrical system. Is there something my dealer should be checking here? Is this a common issue? Any help or suggestions would be greatly appreciated!
Old Oct 14, 2004 | 12:23 PM
rominl's Avatar
rominl
exclusive matchup
it's definitely not a common issue, i have never heard that before. i hope you still have warranty on the car, coz' sometimes these electrical problem can end up with big money. the problem here is it's on and off, if you can't duplicate the problem then it's hard for dealership to help you too. maybe next time if it helps, just don't stop the car and drive to dealerhip @_@
Old Oct 14, 2004 | 12:26 PM
crystalf's Avatar
crystalf
Yeah, that's what the dealer said. Luckily I purchased a service contract with the car and some parts are still under warranty. Thanks for your reply!
Old Oct 14, 2004 | 12:31 PM
Letsride's Avatar
Letsride
I would have them check the lamp failure relay and check the connection to the 3rd brake light (if you have the factory spoiler)
Old Oct 14, 2004 | 12:35 PM
crystalf's Avatar
crystalf
So you don't think that the two issues are related? If its just a tail light or just the window - that I can handle!
Old Oct 15, 2004 | 10:43 AM
amy011079's Avatar
amy011079
wow, very weird. can't say i have ever had that problem either. i hope it doesn't cause you any issues! good luck!
Old Oct 15, 2004 | 03:24 PM
mmarshall's Avatar
Amy's right....this one IS strange. The only possible explanation I can come up with is that there is an internal defect in the power window switch that prevents it from cutting off when you release it...the spring-back machanism is supposed to cut off the current and close the circuit. If the switch pops back normally when you release it, and the circuit inside does NOT cut off, the electric motor will get continuous current and strain........and heat buildup....to the point where the motor's emergency circuit-breaker will prevent it from running at all. Then, once it cools, the motor goes back to normal.....only to repeat the process once you hit the switch again.
Anyone got any other ideas?......that is the only one I can think of.
mate01
Mar 31, 2016 07:36 PM
LIMS407
RX - 1st Gen (1999-2003)
Sep 25, 2010 07:24 AM
carnal_c30
Dec 6, 2005 12:53 PM
Sly1
Lighting
Apr 6, 2005 02:45 AM
NAZTY97
Feb 23, 2003 10:31 AM
