IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
ABS light on???
Old Jul 8, 2004 | 06:52 PM
BOBBYLEXUS's Avatar
BOBBYLEXUS
Default ABS light on???
I recently banged up my suspension an had to get a couple parts replaced an ever since i picked it up from my bodyshop the ABS light has been on..any idea on how to fix it or what might be the problem...thanx in advance
Old Jul 8, 2004 | 07:36 PM
flipside909's Avatar
flipside909
Lexus Connoisseur
25 Year Member
You need to get that reset by the dealer unfortunately.
Old Jul 9, 2004 | 07:01 AM
mmarshall's Avatar
The chances are that the ABS system is still OK even with the light stuck on if no brake work was done, but to be sure, before you go to the shop, it would also be a good idea to test the ABS function on a known slippery surface away from traffic. Hit the pedal hard enough to lock the wheels on the slick surface. If the ABS computer is working properly , you will hear a low grinding sound and feel a slight vibration in the pedal. If not, you will still have regular brakes...just without the anti-lock feature.
I do NOT recommend doing this test on a dry surface because it will require too much pedal pressure to lock the wheels and you will burn off rubber if you do.
Old Jul 9, 2004 | 03:06 PM
BOBBYLEXUS's Avatar
BOBBYLEXUS
Default abs
OK thanx a lot guys i appreciate the info
ninja757
RX - 1st Gen (1999-2003)
Apr 3, 2016 08:07 AM
franco305
Suspension and Brakes
Mar 12, 2015 04:05 AM
gs4mock2
Feb 28, 2010 03:55 AM
ReneV
GS - 1st Gen (1993-1997)
Jan 16, 2009 07:10 PM
carnal_c30
Jan 24, 2003 06:10 PM
