HI
how do you reset the ECU.....i know some people did it to boost the car...i really want to know...thanks for the info btw
You take off the connection/connections of the cars battery and wait about 10min then connect it back. Not sure if you just do one or both though. But that is pretty much it. And what do you mean boost?
Quote:
all you need to do is disonnect the negative side.Originally posted by amy011079
Quote:
The one on the left as you stand in front of the car looking at the battery.Originally posted by baadhabit
That's for people like me that can't remember positive and negative.Quote:
yeah thanks, i couldn't remember. been a while since i've done it. Originally posted by baadhabit
flipside909
Lexus Connoisseur
close
- Join DateMar 2001
- LocationUSA
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:604 Times in 319 Posts
Quote:
Originally posted by princess4
you can also pull 2 fuses from your fuse box in the engine bay so you don't lose your radio presets and clock shizzle
Exactly!!! You don't need to disconnect the battery terminals to reset the ECU...unless you want to keep losing your presets. Originally posted by princess4
rominl
exclusive matchup
close
- Join DateMay 2002
- LocationLovely OC
iTrader Positive Feedback100
iTrader Feedback Score(4)
Liked:463 Times in 338 Posts
Quote:
can you explain this then?Originally posted by flipside909
https://www.clublexus.com/forums/sho...hreadid=116466
On most cars, negative goes to the engine block for grounding.Originally posted by scottc25
