IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
2002 IS300 Questions
Old Jan 23, 2004 | 06:02 AM
mmarshall's Avatar
Default 16" or 17" tires?
Keep one thing in mind, if you are going to switch tire or wheel sizes. Going from a 16" to a 17' size (or vice-versa) could in some cases affect the speedometer, odometer, and other speed and wheel-RPM-related functions. What matters most is the outside circumference of the tire-wheel assembly....conversion charts are available to match tire-wheel assemblies and maintain the same outside wheel/tire diameter and circumference that the sensors that were put on the car at the factory are designed for.
If you decide to go to an aftermarket wheel, make sure, of course, that not only the bolt pattern is compatible, but that the design of the wheel doesn't block airflow to the brake rotors for cooling.
Old Jan 23, 2004 | 04:35 PM
Bahadur's Avatar
Bahadur
I'm sorry, but I am clueless. What do you mean? Do I have to change the wheels to get new tires?
Right now, there is a set of Nankang 215/45/17 tires on the car. Does this mean my wheels are only set for 17" tires?
Again, how does one decide whether to put 16" or 17" tires?
Old Jan 24, 2004 | 12:46 AM
st.lou.is's Avatar
st.lou.is
Default tire size
The last number of your tire size indicates what size rim/wheel the tire fits. You have indicated by your tire size that you have 17 inch wheels therefore you need 17 inch tires.
Old Jan 24, 2004 | 12:56 AM
st.lou.is's Avatar
st.lou.is
Some IS300 owners chose a 16 inch all season wheel and tire option for improved performance during bad weather (and a softer ride as well due to taller side wall). See tirerack.com or tires.com for more info on wheel and tire sizing options.
Old Jan 25, 2004 | 07:10 PM
flipside909's Avatar
flipside909
Lexus Connoisseur
25 Year Member
Originally posted by Bahadur
Is it okay to put 17" "high performance all-season" or "grand touring all-season" tires? Or anything other than summer tires must be 16"?
It's definitely okay to put on 17's but be aware of the huge price differences with summer only tires and "all season performance".
Old Jan 26, 2004 | 12:22 AM
Bahadur's Avatar
Bahadur
First of all, thank you all for replying to my newbie messages.
So, since I have 17" wheels, I looked at Tirerack.com and narrowed my choices to these two all-season tires:
Continental ContiExtremeContact, Size:215/45-17, WR Speed Rated
Pirelli PZero Nero M&S, Size:215/45-17, WR Speed Rated
Would anyone with experiences with these tire care to comment on whether the survey results found on Tirerack.com are consistent with his experiences?
http://www.tirerack.com/tires/tires....omCompare1=yes
Also, Consumer Reports seems to think highly of Falken Ziex ZE 512 tires and Bridgestone Turanza LS-H tires. Any experiences with these anyone?
Hunnicuttz
14
Mar 18, 2015 11:09 PM
twadem
Mar 21, 2014 05:36 AM
k954triniz
Jul 24, 2012 11:01 PM
munki3b0i
Feb 27, 2011 09:22 PM
drft240va
Nov 19, 2005 01:35 AM
