IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Exhaust Advice
Old Aug 19, 2024 | 10:27 PM
UGLYY's Avatar
UGLYY
10th Gear
Originally Posted by TobiasSing
Correct! That P0430 code is telling you that the cat needs to be replaced. There is a second code as well, what is that one? Unfortunately, proper headers with real cats can be very expensive, but the cheap headers on Ebay for about $100 don't fit the best and have more leaks from what I've heard. Perhaps that would work for you if you don't mind the noise/smell. But then you'd still have the CEL because of having no cats. So since you don't have inspections there, you could leave it alone if you are not experiencing any loss of power or other issues. The cats are still working, just not in perfect shape. It can be a lot of work to try and set up fouler systems successfully on the O2 sensor system to trick the CEL into turning off, but it can be done. Where I am, we do have the inspections, so I had to get a full new catted header, and it fixed my codes.
I think I’m gonna go catless because emissions aren’t checked here and I would like my car a little louder lol. As far as getting the CEL off what’s the best route. I have seen people put 90 degree spacers on the back sensor and a straight extender on one of the manifold ones. Is that the best way off getting it off?
2nd code reads same thing.
Old Aug 20, 2024 | 06:02 PM
TobiasSing's Avatar
TobiasSing
ah good it's the same code, so nothing else to worry about. I haven't ever had to deal with O2 sensor bugging, but yeah there are spacers and elbows and stuff that you can try and hope it works. Otherwise, you'd have to find some sort of computer system made for this car, which I have seen in the past, but I haven't seen any lately. My guess is that most people just drive around with the CEL on.
Old Aug 20, 2024 | 08:50 PM
UGLYY's Avatar
UGLYY
10th Gear
I will definitely be trying those spacers. Would definitely like to get the CEL off just so I can see if something else goes bad. If not then it’s whatever. Appreciate all the help on this thread
Mrjohncena
Jun 26, 2018 10:22 AM
mole
Performance
18
Aug 8, 2008 12:13 AM
benlee02
Performance
17
Jan 15, 2007 10:50 PM
joshSETX
Jul 5, 2006 02:00 PM
GS300Rich
Performance
Apr 4, 2003 10:58 PM
