Hi all I just bought new rear adjustable LCAs and was trying to install them when I ran into an issue with the last bolt on the arm. In the pictures you can see that I was able to get the nut off on the end but now that bolt is just stuck in there somehow. I tried tapping the end with a hammer and it didn't even budge? I tried using my jack to relieve any tension on it and even put the other bolts back in then tried again but it is not moving at all! any tips or recommendations? Same on the drivers side as well btw
