RX450H 2010check brake system ,abs and awd system
5th Gear
i own a RX450h 2110 with 138,000 km
Sometime, i have a warning light that say check brake system,awd system and abs system.
All the light turn off after a few miles and another dat all lit.
What is the problem?
thank you
thank you
I experienced something similar today....
But it didn't say to check AWD system, and it specifically said check brake system, not ABS system.
I put up a Youtube video of the errors here: https://www.clublexus.com/forums/rx-...-warnings.html
Did your problem return and what was the fix?
https://www.dropbox.com/s/8dy87hy0ie...110-D.pdf?dl=0
could be related to that, but problem is the goodwill warranty may have expired. (Dec 2017)
While shopping for a used 2007 gs450h I wonder if its a hit or miss, as this part is not cheap at all to replace. (Cost of a battery replacement!)
