Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
Miles on your RX400h?
Old Jan 24, 2019 | 04:23 PM
  #46
professorm's Avatar
professorm
Originally Posted by thomas1
the radiator is cheap at RockAuto.com Around $100 shipped. It is a Denso just like the one in the Car. By the way I now have 235k miles on our 400h
wow! That’s great to hear. I hope to add that many miles to mine now. Have you had any issues with the battery? I hear great things about the RX400h battery.
Old Jan 25, 2019 | 07:07 AM
  #47
thomas1's Avatar
thomas1
So far, no no issues with battery. I just obtained a program to supposedly check battery condition, but have not performed check. It is done thru the OBII connection and thru app on my phone.
Old Jan 26, 2019 | 12:32 PM
  #48
professorm's Avatar
professorm
let me know when you figure it out. I bought the Bluetooth adapter and the app, but I haven’t dug into how to check the battery fully.
Old Jan 26, 2019 | 12:37 PM
  #49
mnewxcv's Avatar
mnewxcv
What app are you referring to?
Old Jan 26, 2019 | 01:57 PM
  #50
professorm's Avatar
professorm
well, I bought torque. But then I saw the Dr. hybrid guy had a few free apps. I didn’t buy those. I was messing with the pics. There is a tread on here that I was following along but I didn’t end up figuring it out exactly.
Old Jan 26, 2019 | 03:45 PM
  #51
mnewxcv's Avatar
mnewxcv
I have torque pro with the rx400h pids. I will help you out if I can.
Old Jan 28, 2019 | 11:56 AM
  #52
Richyb1's Avatar
Richyb1
Talking 2007RX 400h
My RX is at 159K running good.
Old Feb 1, 2019 | 01:52 PM
  #53
riredale's Avatar
riredale
Hi, guys.
I know I'm in the wrong section, I have a 2010 RX450h, so it's 3rd generation, but have to say I'm amazed by all the stories here of cars exceeding the 200K mile mark. Of course, reliability was probably the #1 reason I bought this 2010 RX back in 2016. It currently has about 90K miles, but based on what I'm reading, it's just breaking in.
Best regards.
Old Feb 4, 2019 | 07:31 AM
  #54
WolfyLS460's Avatar
WolfyLS460
Mine has over 180k mi and still going strong.
Old Feb 13, 2019 | 07:02 AM
  #55
mnewxcv's Avatar
mnewxcv
these are the things I monitor using torque pro in my rx400h. My vehicle is not connected obviously, but I can monitor all of this stuff when connected.
Old Mar 7, 2019 | 11:53 AM
  #56
colenzae's Avatar
colenzae
2006 Highlander Hybrid 210,000 miles. Original battery. After replacing rear brake pads, brake actuator failed. Not sure if I initiated the failure by pushing back the caliper pistons. I replaced the pads following the same procedure on my 2012 HS250H with no problems. Oh, well.....too bad I'm past the warranty period. Any links on these forums to a DYI acutuator replacement?? I have installed Techstream on an old Windows XP laptop I had lying around but have yet to connect it to my Highlander. I will get to that ASAP.......
Old Mar 9, 2019 | 09:39 AM
  #57
MadDane's Avatar
MadDane
2007 RX400h bought in September with 113k for $10,000 from Concord CA Audi dealership To replace my beloved 2009 IS350, wrecked by a texting moron! Had a Lexus battery pack relplaced under State Farm insurance (sunroof drain blocked, flooded battery pack) for $7,789.00 at 110k. Had battery, brakes, radiator with both coolants replaced, and brand new tires at 111k. Came with everything but the rear entertainment system. Love the tow hitch and tow package. We got a lot for our money.
Just had timing belt, water pump, idler, etc. done for $1000 as I couldn't find any info that it had been replaced. Good thing too as the chain looked bad @116k and the water pump was leaking. Averaging @22 mpg and we love the ride.
Old Dec 20, 2020 | 08:27 PM
  #58
jonyen's Avatar
jonyen
7th Gear
2006 with 205k. Recently replaced spark plugs, coils, PCV and valve cover gasket. Replaced both pre-cat AF sensors as preventative maintenance. Timing belt was done at same time. Drain and fill transmission. Hybrid system is still original. Was told by Toyota Master tech to drive this car daily in order to maintain the hybrid battery. We had RX330 in comparison the RX400h has been much more reliable. Scotty was right, buy a Toyota made in Japan instead of the ones made in North America.
Old Dec 22, 2020 | 10:14 PM
  #59
professorm's Avatar
professorm
did you pay for that service or do it yourself? How much did you pay?
I need to do my timing belt / full tuneup in the next year or so.
Old Dec 26, 2020 | 07:28 AM
  #60
jonyen's Avatar
jonyen
7th Gear
Been going to the same mechanic for the past ten years. He charges $50 an hour and with parts provided by me. Most of all the things replaced were overlapping labor. thus, 8 hrs was the total. Also, clean the fans by the hybrid battery as well. Good luck!
