Where is tranny fluid fill location on 2008 Rx400h?
I need to add tranny fluid to my 2008 Rx400h but do not have the owner's manual nor do I see a fill point clearly labeled in the engine compartment. I know from this club forum that there is not a dipstick and that the tranny is supposed to be filled to the top of the fill plug, but where is the plug?
There is what looks to be a plastic overflow tank (that is not labeled) on the driver's side of the inverter in the engine compartment. I've assumed that this is not the tranny fluid tank, but can someone tell me what this tank is for?
Thanks in advance for any responses.
There is a pic here that show it. https://www.clublexus.com/forums/hyb...ial-plugs.html
The fluid that I'm trying to replace is that which flowed out of my transmission cooler that I had to remove in order to replace the radiator in my Rx400h with towing package. I'm trying to find out where I fill the fluid that feeds into that transmission cooler (I may be calling the transmission cooler by an incorrect name, but it is the cooler that is nearest the front of the car and which is in front of the AC condenser which is in front of the radiator).
Hope you can help and clear up my confusion.
Thanks,
atlpeter
The transmission in the RX400h is not a conventional transmission where it has a dipstick to check from. It is checked like a differential fluid as explained by smassey321 above. It also uses World Standard Transmission Fluid ONLY.
smassey321; thanks foryour reply on my tranny fluid question, but perhaps I didn't ask my question correctly or I'm missing something about your reply. I'm still pretty green regarding the use of the forum, so that might be why I'm not seeing the picture that you were trying to direct me to. The only pictures I saw were of what appeared to be differentials or axles.
Thanks,
atlpeter
Thanks,
atlpeter
