Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
Two questions about Rx400h fluids
Old Apr 13, 2015 | 03:46 PM
AtlPeter's Avatar
AtlPeter
Default Two questions about Rx400h fluids
I'm hoping that one of you forum members may be able to answer two questions regarding my 2008 Rx400h. Referring to the picture below, please note:
What type of fluid goes into the reservoir labeled A in the picture (the reservoir is on the driver's side of the inverter)?
Does this reservoir feed into the transmission cooler that is nearest the front of the car and which is forward of the AC condenser and the radiator? It looks like it does, but I can't tell for sure.
Thanks.
Old Apr 13, 2015 | 04:17 PM
Rainbird's Avatar
Rainbird
AtlPeter - I moved both of your postings today to the Hybrid Technology Forum. Since both questions are unique to the RX400h you will get more views and faster responses by posting there.
Old Apr 13, 2015 | 09:31 PM
maseace's Avatar
maseace
The pink fluid in the plastic reservoir is coolant (Toyota Super Long Life Coolant). That reservoir is for the inverter coolant loop, which is separate from the radiator coolant loop in the standard location behind the radiator. The transmission cooler is on the driver's side behind/below the driver side fog light, so you are probably describing something else. I'm attaching the repair manual diagram of the transmission oil cooler assembly that I'm describing.
Old Apr 13, 2015 | 09:35 PM
maseace's Avatar
maseace
Here's a photo I took of my transmission oil cooler for reference.
Old Apr 15, 2015 | 08:24 AM
jooksing82's Avatar
jooksing82
Check out the files posted by kknguyen11 in https://www.clublexus.com/forums/hyb...placement.html
The coolant for the inverter goes to a small radiator in front of the Engine radiator. The transmission cooler is on the driver side bottom opening in the bumper as shown by Maseace.
saleenssc
15
Sep 16, 2019 03:34 PM
bcorey
Dec 31, 2016 06:34 AM
333arod333
Aug 11, 2013 11:30 AM
micell2
Maintenance
22
Mar 6, 2005 06:22 AM
Jmai22
GS - 1st Gen (1993-1997)
Feb 20, 2003 11:33 AM
