My car makes a funny sound
Not to bring up an old post...but!!!!
I too am having this same issue. It sounds like the brakes are clicking (as if they are moving in the caliper, which they should a little).
In trying to solve this myself while I was driving I put my vehicle in Neutral while coming to a stop where I know I would normally get the clicking noise.
No clicking while the car was in neutral. I repeated this several times. Same results, the clicking only happens when the transmission is engaged.
So it definitely isn't the brakes. I am going to look at this axle nut! I really think this is it!
And any update on the clicking? Has it come back?
Glad I found this old post, I started having this weird sound, sounds like a single light beep of a horn upon slightly harder than normal stopping. Also a slight single click upon slightly harder acceleration.
Got out my electric impact driver, tightened the axle nut by just about 1-2mm, sound is gone, been a week already.
Something in the axle , spindle, steering, suspension components on that side was causing the noise but just that slight tightening seems to of put it right again.
To do it right, please get the spec for the axle nut and set it right. Then trace the source of sound, which can be the retainer springs for the disc pad [example].
Salim
ThreeCW (07-10-22)
