Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
Electric Steering???
Old Aug 9, 2012 | 08:54 PM
blubyu88's Avatar
blubyu88
Default Electric Steering???
Hey guys, as before I stated I am new to the Lexus world, anyway when driving my 400h I noticed at lower speeds or cruising speeds if I move the steering wheel slightly to the left or right, I noticed it will push back real quick like almost snatching and then after you grab the wheel to keep the car stabilize and straight, it stops and only does it when you move the wheel when cruising it does it pretty abrupt if you turn it slightly? Any suggestions? Kind of reminds me of a old Honda CR-V with being front wheel drive and having torque steer, when you would give it gas.
Old Aug 9, 2012 | 10:56 PM
maseace's Avatar
maseace
I'm not sure what you are asking, or what the problem is. Can you rephrase the question?
It does have fully electric power steering as opposed to hydraulic power steering. All systems that would be vacuum or hydraulics operated on a normal car, are fully electric on a hybrid like the RX400h. The air conditioning, brakes, and steering all have to work without the engine running, in electric-only mode.
One more thing that may explain your steering issue is the VSC, vehicle stability control, that engages the brakes individually when swerving at highway speeds, to keep the vehicle in a straight line and prevent it from spinning out of control, especially in bad weather conditions.
Old Aug 10, 2012 | 01:18 PM
rcy's Avatar
rcy
There was a recall on the 2006 400h for the electric power steering rack. Check with Lexus US (call them and give them your VIN # and ask them to check for outstanding recalls). Something to do with the magnets coming loose inside the rack and the steering sticking.
There were several other recalls as well (crankshaft pulley, inverter (this is a big one), carpets). Make sure they've all been done. Being a 2006, your inverter may be an early one, and it seems the earlier models are most affected by the inverter recall.
Old Aug 10, 2012 | 08:32 PM
blubyu88's Avatar
blubyu88
Ok great info guys, I called Lexus US and they said there is currently no recalls on my car, if a recall was fixed do they remove my car from the cars affected. I see on my service history through lexus drivers, it says steering was worked on a year ago and the invertor said it had been worked on 4 months ago. Could the steering be messing up again? If I took it into lexus would they be able to tell me anything since it looks like it has already been addressed a year ago? Thanks guys!
Old Aug 10, 2012 | 08:56 PM
RX330inFL's Avatar
RX330inFL
Never hurts to go there and talk to them. Ask if they can test drive with you there to try and duplicate. Since these things can be subjective, they may need to be shown what you are experiencing.
Sondoan
NX - 1st Gen (2015-2021)
Nov 7, 2016 10:35 PM
YotaCarFan
HS 250h Model (2010-2012)
Aug 10, 2010 06:56 PM
gdave
May 24, 2010 08:06 PM
SC400TT
Jan 27, 2005 09:32 AM
