Hybrid Technology Unique topics related to the GS450H model hybrid drivetrain and other features/options found only on the GS450H. Please use the main 3GS forum for discussion about shared components with other third generation GS models.
Old Dec 15, 2014, 03:31 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: General Overview
Print Wikipost
GS 450h Performance increase!!!! Help Help!!!
Old Feb 22, 2012 | 07:54 PM
neurocity's Avatar
neurocity
Not quite my tempo
Lets figure this out
Who was the the guy that raced a GSh through Canada? Lets see what he did, he had some dealings with Lexus. Maybe he could get some names.
Old Feb 22, 2012 | 08:51 PM
Stormforge's Avatar
Stormforge
executive matchup
are you referring to the targa newfoundland rally (see link below)?
https://www.clublexus.com/forums/gs-...-race-car.html
Old Feb 22, 2012 | 08:52 PM
LexFather
Guest
Posts: n/a
I saw HAL and Prince and lost it
Old Feb 22, 2012 | 08:57 PM
Stormforge's Avatar
Stormforge
executive matchup
here's the rally results, with the driver & co-pilot's name (rank #6):
http://rallyscoring.com/results/2008...2008Press0.htm
more info in this link (scroll down to near bottom of page):
http://blogs.canoe.ca/targa/
Old Feb 22, 2012 | 09:06 PM
neurocity's Avatar
neurocity
Not quite my tempo
http://www.newswire.ca/fr/story/3386...h-hybrid-power
Old Feb 23, 2012 | 09:11 AM
BNR34's Avatar
BNR34
Originally Posted by neurocity
Trust that I am still on a quest to amp the hybrid drive.
If anyone wrecks or totals or knows where a totaled hybrid drive and battery is... I would be all over it. I know there is more power in that drive line. I know that Toyota cut back on what that trans will throw down. I know that with a code re-write you could improve percentage of power on take-off. Improve throttle response.
LEXUS, you hear me!
Of course you can mod it, you can mod anything. I don't follow the modding scene on the GSh, I am surprise no one modded it yet. Maybe again is a Japan only thing, because I heard even the Prius, people have modded it to go fast with great success. Pretty stock Prius with the ECU modded for full power can do 0-60 in 6 seconds I heard...........that is crazy FAST for a semi stock Pruis.
Old Feb 23, 2012 | 09:39 AM
neurocity's Avatar
neurocity
Not quite my tempo
^^^ Links... show me links to these tuners.
Old Feb 23, 2012 | 10:54 AM
passnu2's Avatar
passnu2
^ we can just do this in my garage. why pay a tuner
What would you like done
Old Feb 23, 2012 | 11:24 AM
neurocity's Avatar
neurocity
Not quite my tempo
Okay Mike... make it so i can disable my traction. Get 30% more power out the the EM.
Lets figure out how to lighten the car up a bit.
Old Feb 23, 2012 | 11:28 AM
BNR34's Avatar
BNR34
I don't have the specific details, one of my car buddy was just telling me. Google and search the Prius's forum is my suggestion to you.
It makes common sense, if you crank up the electrical side of the powertrain and completely ignore the gas saving benefit, I am sure you can gain a huge amount of power.
Old Feb 23, 2012 | 12:58 PM
neurocity's Avatar
neurocity
Not quite my tempo
Oh I've looked, there is nothing much that they can do either. One guy turbo'd the car, but had lots of problems.
Old Feb 21, 2013 | 11:17 AM
NiftySVX's Avatar
NiftySVX
I would love to get more power from my GSh too.. but sadly it is pretty much impossible without a software change. The hybrid ecu monitors torque output to the tailshaft and I would bet money it won't put down more than you should be able to get with a stock setup. It would be nice if it would let you put down all 250 Kw at low speed though. The car is plenty fast but it could always be a little bit faster.
The real trick would be to figure out a way to put the AWD from the 350 on it!
Old Feb 21, 2013 | 12:07 PM
neurocity's Avatar
neurocity
Not quite my tempo
Put AWD from the 600h... Aisin makes two versions of the HSD. 2wd and 4wd.
You would have to increase the battery size and output, the inverter output, reprog the entire system. Then beef up the cooling system.
Much easier to lighten up the car the HSD is in.
Old Feb 25, 2013 | 09:57 AM
Stormforge's Avatar
Stormforge
executive matchup
You could install a Tom's supercharger, but I don't think it's available anymore for the GS450h. NOS could be another option, although I don't know of anyone who has tried that.
Old May 15, 2013 | 04:47 AM
RA21825's Avatar
RA21825
But its not going to rev, you don't even know what redline is on that car
I plugged my OBD II tool in to my car, and it shows ECU data, shows it revved to 6500 rpm on full load. Deceptive cause it doesnt sound like it.
And an interesting thing i found is that the ECU treats the hybrid as a turbo, when it uses hybrid+engine it shows boost on vacuum sensor, i thought that was a neat trick.
