Hybrid TechnologyUnique topics related to the 2010 - 2015 RX450H model hybrid drivetrain and other features/options found only on the RX450H. Please use the main forum for discussion about shared components with other third generation RX models.
the funny thing is that it is on the black hood part of the instrument cluster...since it looks like its relatively the same blue color as the backlighting, then would it be some sort of reflection or perhaps a missing cover?
good point, that's another possibility...
i think the only way to find out for sure is for the OP to take his RX to the dealer and have it checked out. there has to be a good explanation for what those blinking blue lights are.
The thing is, no button to press for blue lights to come on or go off, they come on randomly, unpredictably, can be one side and can be both. It seems like the blue light/beam is behind a cover which is about the size of the letter " O " on your keyboard.
I personally think that they have nothing to do with anything, they are there for show. But since nobody else has these blue lights, I wonder if I shall be happy or worried. Double checked the entire manual again today and did not find an answer. Googled it but keeps bringing me to this post.
May be some of us should give a dealer a visit and check out their 2011 450h on the floor. You can feel the "dot" when you put a finger at the area. This sounds kinky, he, he. My dealer is quite a distance and I won't be visiting them soon since I get regular oil change at my nearest mechanic.
I will try my best to get more info about these blue lights and post it when I can.
now that's strange...you should not be able to feel the "dot", as the gauge is clear plastic and you shouldn't be able to feel anything??? it's not like the gauge requires tactile touch....
if the dot bothers you, my suggestion would be to use black electrical tape and cover the blue dots so that you can't see them.
glad it's not april 1st; if it was, i would have thought you're trying to pull a fast one on us!
In your pictures you said that the sun was in front. Do the lights only appear when there is bright light outside of the car? If so have someone watch the lights while you use something to shade areas around the windshield. Maybe this is external light coming in from somewhere and making its way through a vent hole in the display and appearing as if it is a light. If that is the case maybe a cover/shield is missing allowing the light to enter.
I do not remember if the intensity of the display lights is adjustable in my 450h. They were in every other vehicle I have owned. I am just to lazy to go look now!! If they are adjustable, try varying the intensity to see if the lights vary with the rest of the display. That would tell you if the source is tied into the display lighting.
Yes, the lights are outside the clear plastic cover and under the cluster's 'hood'.
They come on not because of the strong sun but also at night. Like I mentioned before they would come on and go off uncontrollable and unpredictable.
These 3 photos below were taken without the engine on and a digital camera with flash was used. Just found out that the covers are actually blue hence the lights are blue. I'm certain that these blue lights are for show only, but why won't they just stay on both sides at all time? Please pardon the dust around the dash. Time to 'swiffer'!
That was enough to make me get the flashlight out and go to the garage and take a look at my 2010 450h. I do not have the lights but the other larger indentations that you show are flush on mine. I have no idea what they are for either.
Since your dealer is not close by, maybe you could just give them a call and talk with them about it.
Those are the missing "Homelink button illumination lights". Oh man, Lexus is so close to getting that right!! Three more feet up and towards the middle and they'll have it!!
they dont look aftermarket at all, they are perfectly spaced on each side and looks very purposely done. I am extremely curious if the dealership can even answer what this is since we all seem to be more informed than most people
Time to start a pool. Guesses should be accompanied with $5 USD. CL-RX member with guess closest to description given by the owner wins. Owner not permitted to participate. Ties broken by time stamp on answer.
