Hybrid Technology Unique topics related to the 2010 - 2015 RX450H model hybrid drivetrain and other features/options found only on the RX450H. Please use the main forum for discussion about shared components with other third generation RX models.
Towing with the 450h
Old Dec 10, 2010 | 07:11 AM
JimH2's Avatar
JimH2
Thank you "Lucasb7" for posting the web site for that great info and illustrations. Remarkable how the system functions. On the towing (or pushing) capacity in reverse, the engineers and physics folks need to create a basic chart/table showing the capacity to move a trailer in reverse at various inclines and weights of the trailer. I assume that reverse will work on level ground where a 3500 lb. trailer can be moved. But, what are the limits to moving a trailer (various weights) at different inclines (degrees). This is definitely a factor for some folks that expect to tow a trailer and need to use reverse on occasion (on various inclines). I only use my hitch as a bicycle carrier, but I would be very dissapointed if I purchased this to tow a boat or trailer.
Old Dec 10, 2010 | 07:12 AM
DunWkg's Avatar
DunWkg
Thanks for clearing up my confusion about MG1 and MG2, MG3 (traction motors).
How can this simulation be replicated in real life. I haven't been able to get this sort of speed out of MG2. I suppose it does it momentarily and not sustained.
Thanks too for clarifying power and speed in reverse. Interesting effect on towing.
Old Dec 10, 2010 | 02:34 PM
lucasb7's Avatar
lucasb7
CL Folding 500,000
In all likelihood you have gotten that situation to occur. MG2 is the only part of the planetary gearbox that has a fixed relationship to the speed of the wheels. If you spend more time with the diagram you'll see that MG2 is the only motor that changes vehicle speed. So if you're going 60, MG2 will be turning at ~3500 RPM no matter what. If the car needs more power it will up the ICE's RPMs which also raises MG1's RPMs accordingly.
Keep in mind that the "power gauge" has very little correlation to the speed of any of these motors/engine. It is more a summation of how many kW's the car thinks it is putting down with combined output from MG2 and the ICE. Prius owners often use a ScanGauge to determine engine RPM but I don't think it displays the speed of the motors. It will display the amount of energy being fed to the motors though.
At top speed, MG2 and the ICE will both be spinning at their respective redlines.
Old Dec 18, 2010 | 07:42 AM
SLegacy99's Avatar
SLegacy99
Interesting problem. Definately a major flaw. I would like to see a smaller ICE and more powerful electric motors in the RX's future, of course made possible by Li-Ion batteries. That would certainly help with this problem, but perhaps not remedy it.
Old Apr 27, 2015 | 11:52 AM
lovemylexu's Avatar
lovemylexu
Default Down side??
Originally Posted by lucasb7
The only motive force in reverse is from MG2 or in the AWD cases MG2 and 3. In some situations (e.g warm up or charging the battery) the ICE will fire and rotate MG1 to charge the battery but it cannot put any direct power to the wheels in reverse. The best it could do is maybe fire up to charge the batteries to give juice to the motors.
The only suggestion I could give you is to do a force charge of the battery before you try to push the boat up the ramp. To do this, in drive press the gas and brake at the same time. You can watch the battery's state of charge increase on the display. With all bars, the car should theoretically be able to put down more power. You might try this somewhere where you could just go forward if this doesn't work to avoid the tow...
That is certainly a downside I never considered when I was looking at the RX450h.
I haven't found any downside to owning an RX. I have been an owner since 2008 and we pull our boat everywhere. Sounds very unusual that the front of your vehicle would be down by the water and you are backing your boat up the ramp. Sounds like this once a year pull should possibly be handled by a heavy duty truck and not a luxury SUV.
Old May 7, 2015 | 06:10 PM
NateJG's Avatar
NateJG
At the risk of insulting anyone's intelligence; and with apologies in advance should hat occur; and with an assumption that a trailer with a capacity of 3,500# will have trailer brakes; and in the further assumption that said trailer brakes are surge/hydraulic (and here comes the risk of insult) does the brake have a "backup" setting - in which the surge brake is locked off so that the tow vehicle isn't pushing/backing the trailer up a steep incline with the trailer's brakes applied?
My trailer has one; and I've been known to forget to throw the lever - fortunately my drive is short, and the incline moderate.
3894days
RX - 3rd Gen (2010-2015)
Aug 28, 2023 12:05 PM
klyns01
Hybrid Technology
Aug 23, 2017 01:08 PM
funglenn
Jun 24, 2013 12:02 AM
stoumtj
GX - 1st Gen (2003-2009)
Nov 20, 2004 04:26 PM
