Hybrid Technology Unique topics related to the 2022 and up NX hybrid drivetrain and other features/options found only on the NX Hybrid models. Please use the main forum for discussion about shared components with other 2nd generation NX models.
Ionic Emergency Starter Installation Question
Old Feb 23, 2026 | 10:47 AM
DigMyM35x's Avatar
DigMyM35x
Default Ionic Emergency Starter Installation Question
Hi everyone. Going through some old threads about the 12v battery drain issues and noticed this Ionic Emergency Starter that a number of members have posted about.
Here is a link to one of the more expensive sites (available on a number of other sites for about $30 less) but it has the installation manual in the ‘documents’ link so I thought that might be helpful for some people.
https://lithiumhub.com/product/emergency-start/
I was specifically wondering where and how this would be installed on a 450h+.
Would anyone mind sharing their experience and even some pics or video if you wouldn’t mind?
I am not a ‘car guy’ so messing with the battery and electronics have me wanting to make sure I understand 100% before buying and attempting the install.
Thanks so much in advance!!
Old Feb 24, 2026 | 05:34 AM
Davismt55's Avatar
Davismt55
I used a small socket to temporarily remove each post nut, looped the respective (+/-) cable on and screwed the bolts back on. 5 minute job. Be sure to charge the unit first tho using a trickle charger (simply clamp the alligator clip to the flat round wire end). Hope this helps!
Old Feb 24, 2026 | 10:26 PM
DigMyM35x's Avatar
DigMyM35x
Thank you! So you installed on the battery itself under the trunk floor then? Did you use Velcro to attach? How is the fit?
Also, did you ha. To disconnect anything to avoid electrical issues or just be careful not to touch the connectors.
Thanks again and sorry for all of the questions!!
Old Feb 25, 2026 | 04:00 AM
Castrum's Avatar
Castrum
Veteran: Canadian Forces
Default Lexus NX450h+ Battery Studs
There is no need to remove the battery post nuts ... there is enough threaded stud above the factory clamps to add another stainless steel nut to hold down the connectors for the Ionic and also the quick connect wiring harness for my NOCO Genius charger (with the
large M10 eyelets large M10 eyelets
). Sorry, I can't recall the size for sure, but I think they are M8-1.25 threaded studs.
Davismt55's Avatar
Davismt55
Yes and yes. No electrical worries. Note: I will remove this before my 5K service to avoid any warranty issue with Lexus. But I'm also getting them to perform a deep battery check as it pretty quickly falls into a "Low Charge" range. I want my concern documented for any future replacement.
Old Feb 25, 2026 | 04:01 AM
Castrum's Avatar
Castrum
The attachment leads from the Ionic are quite long. I installed mine on the floor of the battery compartment.
Old Feb 25, 2026 | 06:27 PM
DigMyM35x's Avatar
DigMyM35x
Great info - thanks so much everyone, I really appreciate it!
GOLDSc300
Aug 13, 2021 03:05 PM
Andruu
Mar 28, 2019 07:16 PM
Beka1986
15
Aug 13, 2016 07:48 AM
aks92sc400
Dec 7, 2013 05:44 PM
96es300q
Sep 27, 2013 05:41 PM
