Transmission Fluid drain/refill DIY
I was looking for a DIY but could not find one here or on Youtube. I understand I need to use ATF WS fluid. Are the drain and fill plug washers the same as with the oil pan? Can I do this with the front of the car lifted only, i.e. not 100% level? Last tranny fluid change on my car was with 125k miles and it is now at 200k so I think I should do it. Comments?
All drain/fill washers are the same part, 90430-18008
Car needs to be level, how often to change is up to you. On my Highlander I've done it every 60,000 miles probably overkill but the car will easily pass 300,000 miles with zero issues.
If you sincerely think your 300,000 mile belief is true, how do you explain your 60,000 mile actions? 🤔
So what's the correct PN for the gaskets if doing a transmission fluid change? 2x of 90430-18008 or 90430-A0003 as mentioned in some youtube videos I've seen?
How about the engine oil plug gasket? It's the 1x of the blue ones that @NdYAG posted? What's the PN for that?
I think if doing the inverter/engine coolant change, then 1x of 90430-18008 is the correct one as well?
It was the correct washer for the ecvt drain and fill on my 2016 Es300h ☺️
IS250blue
Sep 5, 2022 01:43 PM
DMPesso
Nov 15, 2020 01:01 AM
