Who hasn’t changed their transmission fluid ?
Just curious if there’s anyone with high miles on original transmission fluid. I just picked up a 99 gs400 130k and it seems the transmission fluid was never changed looking at service records but the car drives great. Just wondering if it’s even necessary.
There is a drain plug in the bottom of the trans pan. You will not get it all out of course, but if you do it twice a few hundred miles apart, you'll replace about half.
I used a MightyVac through the fill tube and was able to get just a little bit short of three quarts out each time.
Make sure you use the correct spec fluid when replacing.
Thanks everyone. At first I wasn’t sure if it was ever changed so didn’t know if it was bad to do it for the first time at 130k. However I found hand written service records and it seems he changed the transmission fluid along with the rear differential fluid so I will continue to do that every 30k or so
I would just drain the oil pan, measure what you got and refill. Then remove one line from the oil cooler, put it in a drain bucket, have a second person start the engine and as soon as bubbles come from the line, shut it off. then measure and refill again. this way you get the whole system flushed quicker. repeat 1-3x. after that check level on dipstick.
iRX400H
Oct 7, 2020 05:44 PM
mzeitlin
13
Jun 11, 2020 10:29 AM
