Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
Brake Actuator Replacement
Old Dec 13, 2023 | 02:19 PM
Originally Posted by dpleticha
There are two pins on the ODB2 that you can short out with a paper clip that will allow you to bleed the brakes. Haven’t done it myself but it somewhere on this site if you look hard enough…
I've read that as well never tried it. I didn't even bother going into service mode or hooking up a scanner when I replaced my Highlander radiator simply cranked up the heater that did the trick.
Old Jan 1, 2024 | 12:58 PM
professorm's Avatar
professorm
Wow, didnt know the brake booster was a concern on the RX Hybrid and Highlander. The issue is common with Prius.
Old Jan 24, 2024 | 04:12 PM
colenzae's Avatar
colenzae
So I replaced my actuator and the wiring harness broke...brittle plastic from age. Anyone know where I can get a replacement pigtail connector? It seems to be attached enough to get activity from the actuator but I'd like to make sure its securely attached...
colenzae
Hybrid Technology
May 16, 2026 07:32 AM
Parrokeete
Nov 17, 2021 08:50 AM
Brucemac
Jun 22, 2018 09:30 AM
doggystyl
RX - 3rd Gen (2010-2015)
Jun 23, 2017 07:15 AM
amiehe
Suspension and Brakes
Apr 26, 2011 08:24 PM
