Five Months In, Questioning EV Function
That view has not changed, but I do have questions about the EV function. During the five months/6,000 miles we've driven her, the car has never been in a shop except for emissions testing.Having never owned or driven any sort of hybrid previously, I had certain expectations that may or may not be grounded in reality. I've been accused by some of being too "verbose," in some of my posts, I'll try to keep it simple, with bullet points and this summary statement: I'd like the EV mode to engage and endure for longer periods of time than it does and I expected to see a greater spread between city mpg and highway mpg (city better by at least two mpg). Here's some points to consider -
* I'm in Southern Nevada and recognize that 60% of our ownership period has been with daily high temps >100 and that battery performance will be impacted.
*Sitting idle, usually with AC operating, EV mode remains on for inconsistent periods ... sometimes close to five minutes, others less than one minute.
* Beginning a gentle roll on level ground, EV mode seems very short-lived; any more than 5 mph, and the engine fires, even with the gentlest gas pedal input.
*I might have seen all bars filled on the Energy Monitor battery icon once, but the best normal observation is six maximum, but four typical (are there eight bars total?).
*MPG since reset is 26.3, best tank MPG observed 27.5 on a 100% freeway road trip with included some mountains, but mostly flat near sea level driving at 70 mph.
*Energy bar graph approx. 26 MPG for most of its life, with about a 1 mpg decline in 2023. One bar in 2018 shows nearly 40 (obviously an anomaly).
Guess I expected more from the EV mode; tell me I'm deranged, if that's the case! But I thought that in serious stop and go driving, the EV mode would really shine. Sadly, my daughter's 2009 RAV 3.5 V6 equals the fuel economy of the 450H. I know there's a weight difference. But still, I'm disappointed.
To get a good test on Hybrid battery health, must I go to the dealer? Or a good indie shop? What about DIY through the OBD2 with something like Hybrid Assistant?
I'd appreciate any insights regarding what I should realistically achieve with EV mode and whether or not I may have a sickening hybrid battery. Thanks!
tl;dr: your car is working exactly as intended. In my experience HSD increases fuel economy by about 20%.
Like I said before, perhaps I'm just a dreamer. But it's good to hear that our RX is probably performing within the realm of reasonableness. Thanks.
There are a bunch of vids explaining how HSD works, it is an ingenious system but don't mistake it for anything but gas engine propulsion. Without the gas engine at best you can drive 1 mile at very low speed, in my Highlander best I've done is about 0.6 miles without the gas engine running. All the energy comes from the gas engine (and a small amount from regen braking), the battery is a small buffer that improves the power and torque curve of the engine.
On the over 25 mph EV use, you are dealing with smaller battery size in a hybrid vs EV and some compromise was made to keep the total cost competitive with ICE model IMO. BTW, I can travel about 2 miles in EV mode on flat with steady pedal at 25 mph or so with full battery.
2009 Rav 4 V6 is rated at 19 city 26 hiway.
https://www.edmunds.com/toyota/rav4/2009/mpg/
It is difficult to try to get the vehicle moving completely by battery, and maybe unsafe if you are in traffic. You may want to switch tactics of using the EV just to maximize glide instead of trying to get pulse and acceleration out of it. Assuming everything is warmed up, charged, and ready, once you get the vehicle up to say 30mph, if you lift off the throttle, it should still drop into ev mode, then you can feather the throttle to maintain the speed via the battery.
If you are in +100F, possibly a lot of your poor mileage is due to AC. Especially your comments that the ICE cycles on when stopped.
Your comments that battery meter only cycles between 4-6 is not common. For me it easily goes to full, even a couple hundred feet hill descent it will fully regen and start engine braking. On a flat highway drive it drifts just with top 2 bars. There could also be something mechanically wrong like a stuck brake causing your car to drag and not regening well (as well as your tires if they are not LRR and "only" inflated to recommended).
Finally, fuel may be an issue, since we're going to winter fuel this should get better, but this may only be slight factor.
My RX goes to ICE and ECO all the time at low speed in heavy traffic, and the nice thing about the hybrid is that when in heavy traffic the A/C can be on with no degradation in power, because it the compressor is powered by a small electric motor
