getting a code u0100 and u0101 ,may be related to trans ,took to dealer they say something about pcm and ecm may need to change ,any thoughts. Thanks Alex
have you any knowledge on what is needed to fix this I am now experimenting these codes and I’m at a loss I’m not under warrranty so any info would be great
No, however you should first check your 12 volt battery as when it gets weak it can cause lots of different warning errors.
You should also try a Google search on those codes. However, the codes are just a map that leads to what is maybe causing them. What is the year and mileage of your HS? https://www.google.com/search?q=code...hrome&ie=UTF-8
Actually I have a ls460L 2008 130,000 miles. I been google like crazy but haven’t come up with much info. I know the dealer is only going to want replace the Tcm I was hoping there was other things I could check first.
Never go to the dealer with a 12 year old car, you are asking to get raped. Find a good independent import specialist. I suggest you look at the recommendations in this link. It contains recommendations from listeners of the old NPR car repair radio show, Car Talk. You can search state and town. https://www.cartalk.com/mechanics-files
