Trouble code P1113
Old Aug 9, 2003 | 01:58 PM
Larry99's Avatar
Larry99
Default Trouble code P1113
Check engine light has come on.
Had someone scan the computer and, using Toyota as the manufacturer, got Trouble Code P1113, which was a transmission trouble code, or so the scanner said.
Anyone confirm this and/or give more details on what the problem might be before I open my checkbook to Lexus.
99 RX300 with 62,000 miles.
Old Aug 10, 2003 | 04:57 AM
ederny's Avatar
ederny
Larry,
I also have a 99 with about the same milage. I looked int he shop manuals and did not find P1113. However, this code does fall in the range of codes assigned to the transaxle and the engine.
Don't know if the Toyota code reader is the same for the Lex codes.
Good Luck
Old Aug 10, 2003 | 09:15 AM
Lexmexico's Avatar
Lexmexico
I have the 99 Service Manual, and no mention of that code whatsoever.
A look on the Internet revealed IAT Circuit Input High.
Old Aug 10, 2003 | 01:55 PM
Larry99's Avatar
Larry99
Is IAT similar to an IAC - idle air controller?
Whatever it is, the code has gone away.
Old Aug 10, 2003 | 05:05 PM
VVT-i's Avatar
VVT-i
If your RX still under 6 years/70k miles warranty for the drivetrain( a 99 RX with 62K), then take it to the dealership. If you're sure that's the code P1113. Are you sure it's P1113 not the P0133?
jasawh
Feb 24, 2018 06:29 AM
diverchris
May 1, 2014 01:20 PM
TCAL
Nov 14, 2012 03:48 PM
Christian8
16
Nov 5, 2006 11:22 PM
