HS 250h Model (2010-2012)
P0012 code
Old Jan 2, 2018 | 12:46 AM
Archdeluxe's Avatar
Archdeluxe
Default P0012 code
My car today read on obdII scanner with P0012. My engine sounds like a loud click or knock when it warm up then quiet. Also it stalled on the highway and I got it towed. I do have oil and now when I start it after the sound the engine dies like no fuel. Any suggestion why this happen? How much to repair?
Old Jan 2, 2018 | 01:12 PM
Clutchless's Avatar
Clutchless
See this http://www.toyotanation.com/forum/75...one-dealt.html
P0012
Camshaft Camshaft
Position "A" Timing Over-Retarded (Bank1)
That could cause a rough idle. Would also have a lack of preformance/power too though. I would clear that out and see if it comes back. Some of the possible causes are dilluted
oil oil
or a problem in the PCV (OCV) system. I would see if the code returns before changing anything.
Someone else said - sounds like your have a problem with your
camshaft camshaft
timing oil control valve sticking or stuck in the open position replace it and the code should not come back ps i have 18 of these in my fleet with 300,000 miles or more so i have seen this before
It may be under warranty depending....However you should have a shop look at it. Our car has the same engine/drivetrain as the Camry hybrid.
PS: I found all of the above by entering "P0012 code Toyota" into Google
msweber97
16
Jul 20, 2014 10:11 AM
xintol
Sep 19, 2012 12:11 PM
sj408
Jan 28, 2012 04:51 PM
Max Power
Aug 24, 2009 04:06 PM
Herm
Oct 31, 2007 06:00 AM
