GX - 3rd Gen (2024-present) Discussion topics related to the 2024+ GX550 models
Transmission Shifting
Old Aug 5, 2025 | 11:48 AM
MidnightMica's Avatar
MidnightMica
2nd gear
Angry Transmission Shifting
It seems to be common knowledge, at least in various Lexus GX550 forums, that a lot of people are experiencing rough and clunky transmission shifts. I went back to the dealer after owning the GX for 2 weeks (200 miles) and spoke with the service manager who then had his lead shop foreman take a ride with me. He said the clunking and jerking was normal and would most likely go away because the transmission was in the process of "learning" my driving habits. I have a very light foot on the accelerator and after 1000 miles the shifting is not one bit better now. The clunking and jerking is very noticeable at slower speeds especially going up hills. Does anyone know if Lexus is working on a fix for this issue? Other than the shifting issue I really like the GX550. We also have a GX460 that shifts as smooth as glass which makes the situation even worse.
I appreciate any feedback from others that are experiencing these same issues.
Old Aug 17, 2025 | 05:01 AM
AJCarrington's Avatar
AJCarrington
2nd gear
As I’ve been researching getting a new GX, I’ve have seen a number of comments on Reddit and FB indicating that Lexus is well aware of the issue and working on a fix (likely a software update). People have also reported that disconnecting the battery for 15-20 minutes helps to “reset” the transmission and the issue goes away…though likely only temporarily.
One last note…it appears that the awareness of this issue at dealerships varies widely. Some are fully aware and openly discuss it; other seemingly have no clue about it suggesting it is “normal” and not an issue.
Old Aug 17, 2025 | 02:41 PM
MidnightMica
2nd gear
My dealer here in Knoxville TN is of the opinion that the transmission is shifting normally.......WRONG. I have tried disconnecting the battery for 30 minutes and this did nothing to eliminate the problem, in fact, I believe it may be a little worse now. I am hoping by the time I go in for the 6 month service Lexus will issue a TSB to address the problem. Other than this issue I really enjoy the GX, but this is a big black cloud that continues to linger around.
Best of luck with your decision to make a purchase.
Old Aug 17, 2025 | 04:44 PM
AJCarrington
2nd gear
I’m ready to make the jump…just waiting on my dealership to locate/secure allocation one.
Hopefully a TSB gets released soon…completely understand the frustration.
Old Sep 1, 2025 | 06:53 AM
GrdnRxR's Avatar
GrdnRxR
Can anyone who has a dealer that admits a problem, can you provide what was actually done? Flash, reprogram? I'd like to see a copy, so I can take it to my Dealer.
I'm at almost 20K miles. It seems to be slowly getting worse...
Old Oct 10, 2025 | 01:29 PM
JimInTN's Avatar
JimInTN
My suggestion would be to drive the "pixx" out of the car such as jack rabbit starts and hard throttle acceleration at times if possible. Electronic trannies get lazy and sloppy from the easy/light foot syndrome. Drive it like you stole it on occasion and see if it helps.
Old Nov 12, 2025 | 02:11 PM
Ay-nako's Avatar
Ay-nako
Stop the Copy!
Just to give an update, there is a TSB now, we got it performed on ours. It shifts great.
Old Nov 13, 2025 | 07:46 AM
Chavoo's Avatar
Chavoo
10th Gear
Default Tranny Hard Shift
I just checked with my dealer in Melbourne FL and they are not aware of a TSB for this issue. Do you have a TSB number reference we can point to when contacting our dealers?
Old Nov 26, 2025 | 11:38 AM
bleepa310's Avatar
bleepa310
2nd gear
I just had mine done this past Monday. Noticeable difference in the gears. Barely any delay when shifting. Highly recommend having your dealer do it.
FYI* Not many service advisers know about it so I suggest printing out the TSB for them and another copy in the car for the mechanic. I think someone posted it here.
Old Feb 2, 2026 | 08:52 AM
Ay-nako's Avatar
Ay-nako
Stop the Copy!
sorry, just saw this - its L-SB-0042-25.
Good luck!
Old Feb 9, 2026 | 07:38 AM
LEXUSDIAG's Avatar
LEXUSDIAG
1st Gear
Is the shift memory just being reset or is the software being updated with the tsb?
Old Feb 9, 2026 | 09:12 AM
2959's Avatar
2959
Software re-flash of ECM;
Flash reprogram the ECM (PCM).
NOTE
 The battery diagnostic tool MUST be used in ECU Reflash Mode to maintain battery voltage at
13.5V while flash reprogramming the vehicle.
 For details on how to use the battery diagnostic tool, refer to the DCA-8000 Instruction Manual
located at TIS – Diagnostics – Tools & Equipment – Battery Diagnostics.
Follow the procedures outlined in Service Bulletin L-SB-0036-22 GTS+ ECU Flash
Reprogramming With Security Signature, and flash the ECM (PCM) with the NEW calibration
file update.
Old Feb 25, 2026 | 02:10 PM
Ay-nako's Avatar
Ay-nako
Stop the Copy!
true update - not a reset.
Old May 5, 2026 | 01:33 PM
Chewbrocca's Avatar
Chewbrocca
Anyone successfully get this done in Canada? Which dealer if yes.
Sloopy54
TX Models (2024-present)
17
Mar 29, 2026 02:04 PM
supra46
IS 500 (2022-2025)
145
Mar 2, 2023 08:41 PM
levinsoy
GX - 1st Gen (2003-2009)
43
Sep 30, 2020 03:09 PM
haitianb0i
Jan 25, 2016 06:04 PM
silvertn35
RX - 1st Gen (1999-2003)
17
Mar 6, 2010 04:37 PM
