doors croak when i open and close them
Old Aug 18, 2022 | 02:58 PM
WRD4chano's Avatar
WRD4chano
Default doors croak when i open and close them
can i bathe the door catch in white lithium or________.
video example
Old Aug 18, 2022 | 03:06 PM
If you can find it this works awesome. I don't use it on brake hardware.
Amazon Amazon
White lithium grease to be blunt sucks. Hit those rust areas with Fluid Film.
Old Aug 19, 2022 | 12:17 PM
WRD4chano's Avatar
WRD4chano
https://www.amazon.ca/dp/B078KZDGZB
i know about fluid film, but will it make the noise stop?
Old Aug 20, 2022 | 08:27 AM
John00's Avatar
John00
wd40 works, also generic versions
if the sound is just due to a bit of rubbing its great.
if the sound is something serious then hiding the sound just masks the symptom and doesnt address the underlying issue.
unless theres been some door damage id just squirt in some wd40
Old Aug 20, 2022 | 04:32 PM
WRD4chano's Avatar
WRD4chano
can wd40 and fluid film be mixed? the plan is to wd40 then FF a week later.
Old Aug 21, 2022 | 07:37 AM
John00's Avatar
John00
dont know. might as well just wait. the wd could prevent the ff from getting where it needs to go.
Old Aug 22, 2022 | 12:37 PM
E46CT's Avatar
E46CT
From watching the video it seems the groaning starts as you begin to pull on the door handle, before it "pops," and as the door is swung open. Seems there may be multiple points of noises. I would pull the door panel off and examine everything up close and adjust/lube/fix as necessary. I don't think this will be as simple as spraying "the door catch." First find out what's causing the noise then determine what spray/lube to use from there.
Old Aug 23, 2022 | 05:38 PM
WRD4chano's Avatar
WRD4chano
youre right, but im afraid that ill find rust that will requires a body shop. (i will take it apart once i have time)
another thing ive noticed is it changes based on temp/weather. when its really cold, the door can be difficult to open.
today it was cloudy and 83, and it operated like normal. when i recorded the video is was sunny and 95.
Old Aug 25, 2022 | 10:47 AM
John00's Avatar
John00
could skip fluid film and just put in wd40. easier, quicker, less expensive. so FYI when the sun hits the door it heats up and parts expand. different parts expand at different rates. a CTE issue can cause this. also the parts expand in certain directions. ive seen vehicles that the doors hit the fenders when in the sun a few hours and opening then at night no rubbing at all. I actually checked one out yesterday afternoon, had paint rubbed off the front of the passenger door where it hit.
Old Aug 25, 2022 | 07:26 PM
John00's Avatar
John00
CTE is coefficient of thermal expansion. https://ctherm.com/resources/newsroo...mal-expansion/ differences in CTE between parts that are close together can cause them to hit each other and croak at one temperature and not at another temperature.
GS350Lexus
Sep 4, 2021 09:37 AM
Luxurious
Apr 24, 2020 11:10 PM
Johnhav430
Feb 11, 2020 12:51 PM
PFB
Dec 17, 2010 01:35 PM
BA_GS400
Mar 17, 2005 06:17 PM
