do WOT merges hurt the engine
Old Jan 12, 2021 | 05:57 PM
WRD4chano's Avatar
WRD4chano
Default do WOT merges hurt the engine
had to help a friend out and i merged unto the highway at WOT. he told me i shouldn't do that because it hurts the belt and engine.
i doubt this is true because he usually talks out of his balloon knot a lot, but just incase someone please educate me, because i love doing that.
thanks
Old Jan 12, 2021 | 06:17 PM
No of course not. If you do it all the time then sure you'll wear the engine out faster.
Old Jan 12, 2021 | 08:04 PM
HanksLexus's Avatar
HanksLexus
It’s not an issue at all unless your engine is cold- then you could be causing additional wear due to the oil not being optimal. However, we’re at an advantage with 0-20W which should lead to a long lasting, low wear engine.
Old Jan 12, 2021 | 08:59 PM
ASE's Avatar
ASE
Say What ?#?
Old Jan 12, 2021 | 09:02 PM
HanksLexus's Avatar
HanksLexus
Originally Posted by ASE
Say What ?#?
0w-20 is very good at startup and during warmup because of its low viscosity at cold temps. The cold weather properties give you better protection than thicker oil.
Old Jan 12, 2021 | 10:14 PM
WRD4chano's Avatar
WRD4chano
do that two to three times a week when i have to grab groceries which involves going on the highway
one thing that has been etched into my head after reading it in the manual is, do not race a engine cold.
thanks for the clarification gents😎
Old Jan 13, 2021 | 06:36 AM
situman's Avatar
situman
Occasionally running the engine at WOT is actually good for the engine. Helps burn off a lot of crud from low speed driving and you wouldnt want the engine to be used to small to mid throttle driving only.
Old Jan 13, 2021 | 07:42 AM
GoHuskers's Avatar
GoHuskers
This is a good tip.
Old Jan 13, 2021 | 08:33 AM
bbqsoup's Avatar
bbqsoup
This is what I heard too, more than a few times.
Old Jan 13, 2021 | 12:45 PM
cltchmoney's Avatar
cltchmoney
Good 'ol italian tune up. I pretty much WOT on most on ramps. The GX is definitely not the fastest and the transmission is slow to shift unless you put your foot down or put it in sport mode.
Old Jan 13, 2021 | 04:52 PM
Material's Avatar
Material
I agree. I think it’s good for the engine to step on it occasionally.
Old Jan 14, 2021 | 10:30 AM
Lavrishevo's Avatar
Lavrishevo
I think the best advice is to make sure the oil is fully up to temp. This is particularly important for forced induction engines.
Old Jan 14, 2021 | 04:25 PM
Bitterroot's Avatar
Bitterroot
Just make sure the engine is cold and a couple quarts low on oil. Lock it into 1st and keep it floored till the knocking gets loud!
Old Jan 14, 2021 | 04:29 PM
Lavrishevo's Avatar
Lavrishevo
Originally Posted by Sargon
Good for the engine? No, just wears it out faster
Upwards of 90% of engine wear comes from
cold starts.
Old Jan 15, 2021 | 08:26 AM
crwys's Avatar
crwys
I don't think he was necessarily disagreeing but as much as pointing out WOT is the least of anyone's worries as long as you don't do it 24/7
