GX460 - Tire Size Comparison Thread
Old 08-05-21, 05:59 AM
  #106
xychromo
xychromo's Avatar
Originally Posted by OhMyJosh
I went with BFG AT KO2 in 275/65/R18 and surprisingly - zero rub! I bought the hardware and zip ties to do the bolt and fender mods, but I have zero rub even at full lock. Anyone else have this experience? I will say for all of you looking at this tire size - the pictures do not do it justice at all. The tires are much bigger in real life and make it look semi-lifted.
Consider yourself lucky! Although IIRC, the BFGs run a little smaller than other brands at that same size. I had some rub with that size on my lifted truck but just took some fender massage to take care of it.
Old 08-05-21, 09:41 PM
  #107
OhMyJosh
OhMyJosh's Avatar
Originally Posted by Piney1
Yes and no. At first, no but if I hit a bump and turn, it rubbed. I lifted a tad, wish I had gone w a 1” spacer as it is too high right now. Will fix that sooner or later. Love the tires though.
I looked at doing spacers - probably the 4 Runner spacer since there doesn't seem to be any equivalent for the GX unless I just haven't googled enough. I also read that they compromise the ride. What have you seen from others who have installed them?
Old 08-06-21, 03:04 AM
  #108
Piney1
Piney1's Avatar
I’ve not read up on that but would just do the 1” on the front and 3/4” on the rear if I do it again. Just use the spacers that go on top of the springs. That is not a really fun install but not terrible to do.
Old 08-19-21, 09:19 PM
  #109
Unaffiliat
Unaffiliat's Avatar
Default What size is the bolt
2015 GX 460 Luxury Just put 265/65/18 Michelin Defender LTX M/S getting some rubbing, curious what size the low profile bolt everyone is using??
Old 08-20-21, 08:37 AM
  #110
stevew1522
stevew1522's Avatar
Looks great, love the blue. Don't see that color very often.
Old 08-21-21, 12:34 AM
  #111
dta20502
dta20502's Avatar
Originally Posted by schwein
Stock 265/60R18 Bridgestone Duler's
New 275/65R18 Hankook AT2 RF11's
Couple more photos
"I did remove the "notorious bolt" and replaced it with a flat headed bolt prior to having the tires installed"
Where is the "notorious bolt" and how to get the "fat head bolt" ? Could you post some pictures? Thank you much!
Last edited by DaveGS4; 08-24-21 at 04:57 PM. Reason: removed images from quoted text for readability
Old 08-21-21, 03:19 PM
  #112
left123
left123's Avatar
Read the very first thread. It shows the links for what to do. One of them is the "zip tie and mud flap mod thread", and in that one, someone shows exactly what to do, where the bolt is and other similar and popular alterations. Another post within that thread even includes a purchase list from Home Depot to complete it, which I just completed. It was explained perfectly. Once you get the parts and get down on the ground to look at it, it will make sense.
Warning, you will need patience and some tools to get it done (needle nose pliers, 10mm wrench, philips screwdriver, and most importantly, skinny fingers). It’s deceptively more difficult than it may appear, particularly getting a nut threaded onto the flat head bolt.
Old 09-16-21, 12:25 PM
  #113
GXLX
GXLX's Avatar
Just threw some BFG KO2 275/65/18 tires on my 2021 Lexus GX 460. No mods and zero rubbing so far.
The following 4 users liked this post by GXLX:
45jimmy (09-14-22), jtzunami (02-12-23), JustinFro (09-17-21), NemesisGX (01-14-24)
Old 09-16-21, 01:36 PM
  #114
xychromo
xychromo's Avatar
Looks good, surprised they aren't rubbing. For my rig (2015), that size rubbed when at full lock and this was even after a suspension lift. Some wheel well liner massage took care of it though.
Old 09-16-21, 01:53 PM
  #115
jdam
jdam's Avatar
Were you on stock wheels as well? The high offsets probably help with keeping the tire away from the liner, but 275/65 is still a bit tall.
Old 09-16-21, 02:33 PM
  #116
msgs350
msgs350's Avatar
What are you guys with the tow packages doing for spares? I tried to fit a 265/70-17 tire underneath and didn't have any luck, so i went back to OEM tire size (265/60-18) with F-sport wheels.
Old 09-16-21, 03:04 PM
  #117
xychromo
xychromo's Avatar
yep, stock wheels, see area of rub in photo below.
note that the BFGs run slightly smaller than other brands in that tire size, so that would help prevent rub here I imagine
Old 09-16-21, 03:18 PM
  #118
xychromo
xychromo's Avatar
I stuffed the biggest tire size I could fit on my stock spare wheel; 265/65/18, into the spare wheel well. It's 1/2" smaller than the tires on my truck (275/65/18), but I'm not too concerned at that small a size difference.
Old 09-17-21, 06:26 AM
  #119
Brugada
Brugada's Avatar
285/70/17 Nitto Ridge Grapplers on Summit Offroad Sierra wheels (17x9 with -25 offset), stock suspension without rubbing but did require side step removal/trim, front bumper trim, front fender liner moved forward (trimmed and tucked under and fastened to existing bolt hole where front corner bumper brace was previously) and I did body mount chop using the Metaltech kit.
More pictures and video available on my Instagram page: @gxor.mi
The following 5 users liked this post by Brugada:
2chains (09-24-21), jtzunami (02-12-23), JustinFro (09-17-21), rusn007 (09-15-22), Slprciv (09-18-21)
Old 09-23-21, 08:21 AM
  #120
schwein
schwein's Avatar
Updated the first page adding a bunch of folks who posted up images and specs of their rigs.
One note, if your rig is posted on page 1 and you have a better photo of it, or if my information listed for your rig is incorrect (or if I dont have the year of your rig) please private message me.
Thanks,
2chains (09-24-21)
Quick Reply: GX460 - Tire Size Comparison Thread
