#Sequential #Tail lights
Old Jul 17, 2020 | 06:12 PM
  #91
Lavrishevo's Avatar
Lavrishevo
They really do look good.
Old Jul 17, 2020 | 06:26 PM
  #92
hzhao's Avatar
hzhao
25 Year Member
Originally Posted by Chasin
If it's not too much to ask, can you please snap a photo of the car at night from the side and rear quarter? I want to see what the tail lights look like without the DOT side reflectors. I really like the looks of these lights but safety is most important to me and I do night driving where I am reversing the vehicle out of parking lots and onto busy streets. Thanks!
Here are few side profile photos for your reference. It’s not completely dark outside but the lights are intense and wrapped around enough to provide enough vision side marker effect. not saying it’s DOT complied due to its positions, but enough for others to see if the visual reference at night is important to your concern:
Old Jul 18, 2020 | 08:18 AM
  #93
Chasin's Avatar
Chasin
That looks great!! Thanks Soo much! One step closer to ordering these.
Old Aug 11, 2020 | 07:10 AM
  #94
Flavorus's Avatar
Flavorus
Well I got mine last week and got them installed. Guess I'm not so lucky. First run through the car wash, and I've got condensation build up on the inside of the lens. I contacted them, and they told me I need to use silicon to seal them up. Not something something you want to hear after spending $550 on something. Now I'm in a tough spot, considering the logistics of buying/returning something to Dubai.
Old Aug 11, 2020 | 08:36 AM
  #95
hzhao's Avatar
hzhao
25 Year Member
Just buyer beware.
Sorry to hear that. It is one risk fact for small batch production. My guess would be the added black trim piece at the bottom that has not sealed properly. Just using a hair dryer to dry it, then apply the clear silicon seal to the joined part. It should take care of it. I didn’t experience the condensation, but as I was look at the seal they had for the bottom piece, was not very secure and pleased. I just re-seal it for prevention.
Old Aug 11, 2020 | 09:14 AM
  #96
Flavorus's Avatar
Flavorus
Yea that was my thought as well. Were you able to apply the silicon without making too much of a visible mess?
Old Aug 11, 2020 | 09:52 AM
  #97
hzhao's Avatar
hzhao
25 Year Member
Just along the top edge between the black trim and light fixture. You don’t need a lot, just enough, then using a piece of flat plastic or just run the fingers to smooth it out. Silicon won’t dry for a while, and it is easy to wipe the excessive off with a wet cloth. When it is settled overnight or 24 hours or so, it just forms a clear seal. I just using the 3M branded one from Homedepot, located in painting material section.
Old Aug 11, 2020 | 10:43 AM
  #98
CaptRog21's Avatar
CaptRog21
That lower black trim seems to be the weak point for me as well. I haven't had any condensation build up inside yet but the trim is slowly pulling away from the lens. That 3M foam tape just isn't gonna do the trick. Thinking about taking them off the car and using some sort of epoxy to try and re-glue it and then do the silicon seal as described by @hzhao . In hindsight (which is 20/20 of course), I would have spent the extra money and got the sport design tail lights instead of these aftermarket lights.
Old Sep 6, 2020 | 09:28 AM
  #99
Acrad's Avatar
Acrad
Appears to be another version
Video 2
Old Sep 6, 2020 | 04:07 PM
  #100
hzhao's Avatar
hzhao
25 Year Member
Originally Posted by Acrad
This one seems more for Prado as it also incorporated reverse lights. Might need some modification on harness and add a trim at bottom to be fit with GX. Wondering what the cost might be.
Old Sep 18, 2020 | 08:49 AM
  #101
Chasin's Avatar
Chasin
Any update on this issue with the black trim piece?
Old Sep 20, 2020 | 06:51 AM
  #102
TheHighLow's Avatar
TheHighLow
To each his own but Imo, the aftermarket lights look unbalanced and out of place from the side profile.
In particular, there’s too much red unlit portion followed by a tiny lit up strip. At least the oem clears break up the side with alternating red and silver.
Old Sep 20, 2020 | 06:54 PM
  #103
hzhao's Avatar
hzhao
25 Year Member
I do agree. I have also point that out during my initial review. Some simple patten and side marker would make it much better.
Old Mar 15, 2021 | 07:54 AM
  #104
Chasin's Avatar
Chasin
About 1 year later since OP installed these... can you guys kindly post an update on these lights? How are they holding up?
Old Mar 15, 2021 | 08:30 AM
  #105
hzhao's Avatar
hzhao
25 Year Member
Mine has been working well since day one. No issues, leaks, or any other defects at all.
