Rear suspension issue
Old Oct 29, 2019 | 02:24 PM
nhagon's Avatar
nhagon
Default Rear suspension issue
I am having and issue with the rear suspension. I have the rear air suspension. I replaced the shocks and had the entire air suspension ran diagnostics and was told by lexus that everything is working perfectly. Still having the bottoming out issues. I bought the vehicle with 65K miles on it and I know the previous owner towed with it. Is it possible the air bags are worn but not leaking, they hold the ride height but when going over a bump they dont have the resistance needed? I replaced the shocks with KYB's from china and lexus says the only thing they recommend is to replace with factor shocks and see if that fixes it. thoughts?
Old Oct 29, 2019 | 02:36 PM
bbqsoup's Avatar
bbqsoup
You could also look into installing a better bumpstop too. It helps with bottom out
https://www.clublexus.com/forums/gx-...on-videos.html
Old Oct 29, 2019 | 02:37 PM
Acrad's Avatar
Acrad
Edit: bbqsoup beat me to it.
You might want to look into putting some Timbren's in the rear. I really like the feel they give to mine. I even run them in the front. I have AVS/RAHC on my '12 as well. Timbrens can coexist with the system. Another nice advantage is if I do lose a bag system won't be riding on the stock bump stops (which aren't much) but a significant component such as the Timbren.
nhagon
GX - 2nd Gen (2010-2023)
Jun 5, 2019 04:17 PM
RA21262
GX - 1st Gen (2003-2009)
20
Nov 18, 2016 05:32 PM
cglende
Jan 3, 2013 08:25 AM
rklages
Jul 9, 2007 10:58 AM
blessedbigtime
Aug 22, 2002 12:05 AM
