#Mark #Levinson ( #ML ) discussion / questions / problems
Old Dec 16, 2018 | 06:06 AM
  #121
John00's Avatar
John00
Believe it or not, the cheapest el cheapo all in one sub combo box gets good reviews. imagine having this in a GX with the cabin air volume making it sound good then they see what it was
Old Dec 16, 2018 | 06:12 AM
  #122
John00's Avatar
John00
looks like this guy, but im sure the generic speaker sounds better without the echo around 1:45
Old Dec 16, 2018 | 09:37 AM
  #123
mental69's Avatar
mental69
6th Gear
Default Thanks for all the input
The sub was rattling because one of the mounts that secures it to the frame had snapped loose. The fix we plan to do is to make a new enclosure in there using some "slurrie" - kind of a polymer/fiberglass mix. Should do the trick.
Cheers
Casey
Old Dec 16, 2018 | 03:33 PM
  #124
John00's Avatar
John00
Thanks for the follow up. So how is the sound now?
Old Feb 2, 2019 | 08:14 AM
  #125
Im4real1's Avatar
Im4real1
Default Mark Levinson system sounds “hollow” tinny.
I recently purchased a 2016 Luxury GX. Love it so far, except for this supposedly great ML sound system. I’ve tried so many adjustments but can’t seem to get a full sound...Appears to miss “ channels “ of sound. Very weak base no matter the position. Best sound I can get is to position most sound to rear. I feel maybe sound speakers are not responding or maybe blown? Any advice is greatly appreciated. (I’m coming out of a 2011 Infiniti FX (had two for 16 years) which has fabulous Bose sound.)
Old Feb 2, 2019 | 08:39 AM
  #126
Romanova's Avatar
Romanova
Make sure it is adjusted properly? Ours sounds amazing and was a 'must have' when we were shopping for our GX. No matter what genre of music I play, it always sounds great. What source are you using for your music? If you're using low quality MP3s or streaming via BT, the quality might suffer.
Old Feb 2, 2019 | 10:40 AM
  #127
Im4real1's Avatar
Im4real1
Bluetooth sounds the best, actually! I’m going to try adjustments recommended in a prior post.
Old Feb 2, 2019 | 10:41 AM
  #128
Romanova's Avatar
Romanova
I'll try and remember to get a picture of my adjustments when I go out later. The system really sings when it's at volume level 35 or higher too...
Old Feb 2, 2019 | 10:49 AM
  #129
r2m's Avatar
r2m
Mine too sounds great! Just out of curiosity, what type of music are you into? Have you gone through the manual yet?
If you're into hip-hop, rap or other bass-centric genres of music at elevated volumes, yes you may be disappointed.
This was just discussed a few posts ago, and one suggestion I made was that you could add a small amp and sub-woofer.
Good friends of mine purchased new, two years ago a 2017 4Runner with everything and they too were disappointed with the sound and did just that, when to a quality sound shop and added an amp and sub-woofer. The new 4Runners are the essentially the same platform as our GX's (150 series). Note that my friends and I are in our mid to late 50's so if we're needing a bump in sound quality, it's not because we're trying to rattle windows going through neighborhoods.
Old Feb 2, 2019 | 04:55 PM
  #130
Im4real1's Avatar
Im4real1
That would be so great. Thank you!
Old Feb 2, 2019 | 05:01 PM
  #131
Im4real1's Avatar
Im4real1
I listen to classic rock, 60s, 70s, 80s, Beatles, The Bridge, The Blend, etc. via XM. I also listen to Pandora via Bluetooth. Can’t figure out if surround sound is good or not??! Sometimes it’s, good, sometimes, it’s not?? So instead I’ve been listening to a lot of comedy channels! Lol!
Old Feb 2, 2019 | 05:04 PM
  #132
Im4real1's Avatar
Im4real1
I also wonder if it’s because of location of rear speakers behind seats...maybe I’ll put seats down to see if that’s much better
  #133
r2m's Avatar
r2m
Yea, I sometimes listen to Classic Radio on satellite radio, especially if I'm feeling sleepy on a long drive. Focusing on the story helps keep me awake.
I don't notice any difference with seat arrangement.
Old Feb 3, 2019 | 09:36 AM
  #134
Romanova's Avatar
Romanova
Make sure Surround and Automatic Sound Levelizer are ON under DSP, and adjust Treb/Mid/Bass to your liking.
Old Feb 4, 2019 | 10:41 AM
  #135
KJ6IRM's Avatar
KJ6IRM
Play with the Surround setting. I actually prefer the Surround setting to be off. I feel is sounds hallow and unnatural with surround on.
