#Driver #Support #Package
Old Feb 24, 2019 | 08:19 AM
  #136
Acrad's Avatar
Acrad
https://parts.lexus.com/p/Lexus__GX-...646060010.html
Old Feb 24, 2019 | 08:28 AM
  #137
Acrad's Avatar
Acrad
Old Feb 24, 2019 | 01:36 PM
  #138
KJ6IRM's Avatar
KJ6IRM
EDIT: Added rain sensing windshield wipers sensor location.
Old Feb 24, 2019 | 01:38 PM
  #139
Acrad's Avatar
Acrad
Thanks! That's a good trivia piece too about windshield that vehicle is optioned with Driver Support.
Old Feb 24, 2019 | 01:41 PM
  #140
KJ6IRM's Avatar
KJ6IRM
Yeah, no problem. Theres also a different headliner to support the opening of the LDA out the front of the windshield. Also the part you posted showing the LDA camera is missing the metal mounting bracket. That bracket cannot be purchased separately, Lexus only sells the bracket with the camera.
Old Feb 24, 2019 | 01:49 PM
  #141
Acrad's Avatar
Acrad
I found on one of the online parts sites. They probably figure replacement of failed unit to exclude bracket but not likely too many failed units on a rare option. If vehicle was damaged to this extent it would likely find itself again in the wrecking yard or crushed.
Does your vehicle have these "Driver Support" level functions? I know they didn't call it that but simpler to reference from the long winded packages of our generation. I thought you had a '12 like me.
Old Feb 24, 2019 | 01:55 PM
  #142
KJ6IRM's Avatar
KJ6IRM
Does your vehicle have these "Driver Support" level functions? .... I thought you had a '12 like me.
Mine does not, just a lot of looking around to add the options to mine. I have a '12 with the F-Sport package, none of the F-Sport equipped pre-facelift can have driver support. The grill doesn't support the camera or the radar. I wish I held out of a driver support vehicle.
Old Feb 24, 2019 | 02:00 PM
  #143
Acrad's Avatar
Acrad
+1 . If I had to do it all over again I would have done the same.... for better or worse...I am not sure I would have found the inspiration to search out MTS... or it would have been far later.
Old Feb 25, 2019 | 07:53 AM
  #144
jkutti2000's Avatar
jkutti2000
https://www.cstatic-images.com/super...10b26a734d.jpg
https://www.cars.com/vehicledetail/d...8057/overview/
DRIVER SUPPORT PACKAGE W/MARK LEVINSO...
he lists Driver supprot package.. but if u look at the pics.. u cant spot the front camera below the L symbol ??
also steering wheel. right side.. no indication ??
so he is lying ??
Old Feb 25, 2019 | 08:01 AM
  #145
tigmd99's Avatar
tigmd99
so he is lying ??
Clearly, he is misinformed! Definitely does NOT have Driver Support.
Old Feb 25, 2019 | 08:26 AM
  #146
jkutti2000's Avatar
jkutti2000
thank you sir.. i was all charged up.. was gonna go to Houston to check out the car...
as the saying goes. TGTBT.
if something is too good to be true. it aint!...
Old Feb 25, 2019 | 08:27 AM
  #147
plex's Avatar
plex
1UZFE/2JZGTE
Somewhat of a side note question with Height Control what are the lowest and highest settings height wise?
Old Feb 25, 2019 | 08:30 AM
  #148
jkutti2000's Avatar
jkutti2000
THANKS you pic
https://cimg0.ibsrv.net/gimg/www.clu...0b4994df0.jpeg
so the pic here is CRAWL and this one is DAC
https://www.cstatic-images.com/super...9ebc0ac2c2.jpg
so the usual config is .. they put the DAC and CRAWL button to LOWER LEFT and you can get one of the two options ?
Old Feb 25, 2019 | 08:36 AM
  #149
tigmd99's Avatar
tigmd99
THANKS you pic
DAC is mainly for downhill...it controls wheelspin/slippage and slows you down as you come down a hill (off-roading).
CRAWL can do the same, but also works at maintaining speed (depending on setting you select), momentum, and traction going UP a hill. And it will work going down the hill too...thus, no need for dedicated DAC when you have CRAWL. In fact, CRAWL also works going backwards too.
IF you plan on off-roading, wait and get one with Driver Support. If you don’t off-road, then no need for CRAWL. BUT Driver Support also comes with other niceties that benefit on-road travel too such as pre-collision and radar cruise.
Old Feb 25, 2019 | 09:44 AM
  #150
Acrad's Avatar
Acrad
DAC is downhill fixed at around 3 MPH while you get ~1,2,3,4,5 MPH up or downhill with Crawl as it works both the brakes and accelerator. DAC just does brakes.
IIRC... the spread from High to Low on suspension is just shy of 3 inches. I believe spread to H is greater from N than spread from N to L. Remember you can add Crawl and MTS to even a base.
