#Transmission Failure or Issues
Old Feb 15, 2020 | 07:37 AM
  #256
Kbownas's Avatar
Kbownas
Originally Posted by Acrad
If they are already tearing into it isn't much more work to pull down the valve body if needed and replace the solenoids. I don't think solenoids cost that much overall. I've never looked up pricing on them. Not sure what the book time on a job like this is though. Shops usually charge on an estimate of time regardless if it took shorter or longer time than book states it should. I would imagine this is a $800-$1500 job. I could be totally off though.
When he looked it up he said that the book stated 3-3.5 hours I think.
Old Feb 15, 2020 | 07:39 AM
  #257
Acrad's Avatar
Acrad
General parts list of transmission valve body
It does appear these solenoids cost more than I thought... just ran some of the PNs for pricing and they are in the $150-$250 range each
Old Feb 15, 2020 | 07:40 AM
  #258
Acrad's Avatar
Acrad
Maybe then $1K or so for parts and $500 for labor? It could push closer to $2K as well and then any associated taxes.
Old May 1, 2020 | 09:19 PM
  #259
naser075's Avatar
naser075
Default 2011 check engine hlow flashing help
2011 gx460 - 126000 km .
Guys i need help,
since the confinement I have not driven my car very much . Here is the problem explained:
when i come to drive and shift to D , N or R it feels “ buttery” like very smoth to smoth. when i bring the shifter **** to D position I realized the red light did not come up beside it to say it is on D position.Then i drove a little and the dash lights up with the four light flashing.( hlow check engine ,...)
Now the transmission feels the same as usual no issues at all i know my car very well.
30 min into driving and stopping everything dissapeared and shifting is back to normal when moving to D position the light beside the D is red again. Any help would be very usefull.
Old May 2, 2020 | 08:59 AM
  #260
Acrad's Avatar
Acrad
Do you have a code reader? It could be a failing component in secondary air system.
Old May 2, 2020 | 09:24 AM
  #261
naser075's Avatar
naser075
unfortunetly i don’t and code is gone but i am bringing it in to lexus on monday as the sec air system was changed last year
Old May 2, 2020 | 10:28 AM
  #262
Acrad's Avatar
Acrad
FYI: Unless codes were reset the code should still be around as a historical one even if CEL is now turned off.
Old May 2, 2020 | 02:00 PM
  #263
naser075's Avatar
naser075
i found my neighbors code reader it is a LAUNCH CREADER 3001 but it is not reading anything we have tried it all. anything in particular we need to do
Old May 2, 2020 | 02:12 PM
  #264
Acrad's Avatar
Acrad
Unfortunately ..if there were historical could you would likely need Techstream, OBD Link/Fusion, or possibly BlueDriver? There are other diagnostic solutions but they are $$$
Old May 2, 2020 | 02:14 PM
  #265
naser075's Avatar
naser075
so this one will surely not work right we are trying to update the software right now and see i will keep u posted
Old May 2, 2020 | 02:22 PM
  #266
naser075's Avatar
naser075
i got it to work code is P0705
0705 transmission range sensor a circuit (PRNDL INPUT)
Old May 2, 2020 | 03:02 PM
  #267
Lavrishevo's Avatar
Lavrishevo
I believe the code indicates a failing neutral safety switch module. Double check your battery and alternator are good. Auto Zone or Pep Boys will do this for free. Failing power can cause weird issues if it is the case.
Link
Old May 2, 2020 | 03:04 PM
  #268
naser075's Avatar
naser075
Highly appreciate the info
Old May 2, 2020 | 04:12 PM
  #269
naser075's Avatar
naser075
Thanks a million bud reslly appreciate the help i am no mechanic so i will bring it to lexus and have them figure it out. I have a extended 10 year gold warranty so eveything is always covered . Not that i have had many issues with it but i guess it is usefull now
Old May 4, 2020 | 01:37 PM
  #270
naser075's Avatar
naser075
Just an FYI:
lexus replaced this part that was defective
Part number 8454035060
thank you for all the help
