#Coolant #Flush / Fluids / Questions / Comments
Old Mar 21, 2024 | 10:14 AM
  #91
mike202's Avatar
mike202
Hi Folks,
I'm about to do a coolant change to my 2014 GX and would like to double check the part number of the coolant before ordering from the dealer. Is this correct :
00272-SLLC2 (Toyota Genuine Fluid Long Life Coolant)
That's a 1 gallon jug, I think I will need 4 jugs to drain/refill radiator and engine block. Is that right?
Cheers
That is the correct coolant. The service manual says 16.3 qts total capacity.
Old Dec 4, 2024 | 03:45 PM
  #92
Ralo14's Avatar
Ralo14
Is there a process for refilling the system after replacing the radiator and thermostat? Would there be coolant on the engine side of the thermostat since one-half of the block has been drained?
Old Dec 4, 2024 | 03:55 PM
  #93
mike202's Avatar
mike202
Fill the radiator with the engine running, and let the engine warm up with the radiator cap off until the thermostat opens. Top off radiator as required and replace cap and fill coolant overflow reservoir.
Note if you want to do a thorough coolant change, there are two coolant drains on the block, one on each side.
Old Dec 5, 2024 | 07:39 AM
  #94
Ralo14's Avatar
Ralo14
I read the other block drain is hard to get to. Thanks, I just wanted to make sure it was okay to start the burping process without priming the system, for lack of a better word.
Old Dec 5, 2024 | 08:42 AM
  #95
NewB2Lexus's Avatar
NewB2Lexus
The process is described in this post: https://www.clublexus.com/forums/gx-...ml#post4568167
Make sure you set the cabin temp to max heat otherwise you may end up with an air pocket in the heater core.
Old Dec 5, 2024 | 08:48 AM
  #96
mike202's Avatar
mike202
Note that link is for a GX470 radiator replacement. If you are replacing the radiator on a GX460, the fan and fan clutch needs to be removed. The SM calls for the front cover to be removed but there has been some that have done the job w/o removing the cover. Other than that, the procedure is the same.
Old Sep 27, 2025 | 12:22 PM
  #97
Labrati's Avatar
Labrati
I don't think fighting with the driver side drain is worth the payoff - maybe 1/2 - 1 cup of fluid. I started with the driver side because I could easily see it from the underside. This is how I do my Land Cruiser 100's and it's insanely easy. That driver side was a battle. The passenger side from the wheel well took a little work to get a drain hose on the drain and routed through the lower control arm, but draining that was a cinch. Since it appears that regardles of laterality the first one you open on the block is going to be the 5+ quart payoff, I'd just do the passenger. I spent at least 45 minutes with various tools fighting the driver side from underneath on the ground. My ratcheting 10mm spanner would just barely fit with a drain hose. I got just over 2 gallons, including the overflow.
Old Sep 29, 2025 | 11:22 AM
  #98
BenCSVT's Avatar
BenCSVT
The thermostat has a bleed hole integrated into it.
It will flow a tiny amount of coolant (and air) even when fully closed.
I would also suggest this tool, it's a game changer and makes the burping process incredibly simple.
Amazon Amazon
Vinniety
GX - 1st Gen (2003-2009)
31
Nov 4, 2020 03:28 PM
Bastor
12
Dec 22, 2017 01:52 AM
Rolemodel
Maintenance
15
Sep 22, 2007 01:30 AM
ecalica428
Jun 30, 2007 09:06 PM
Lexarse
Maintenance
Jul 21, 2005 08:27 AM
