#Rear #Door #Table Mod
What is the weight capacity of that set-up? Are you going to get it? How much of that is shipping? Where in WA are you? Maybe we can but it and combine shipping?
Last edited by msgs350; Apr 11, 2018 at 07:57 AM. Reason: Added weight capacity question.
It does seem to be high quality. I can see a really general utility having this back there just in everyday use. I sent an inquiry off to vendor on weight capacity. I too like that it still allows the use of both doors. I've seen some that cover up.
msgs350: I asked about shipping discounts as well . (Your PM box is full) :-)
Weight rating is 22lbs.
Example: Roughly half the dry weight of a Honda EU2000i generator
"We list the load rating as 10kg. The limitation on the loading is not to do with the cord that holds up the table. The cord 550Lb parachute cord and is rated to over 200kg per cord. The concern is with the plastic screws mounting into the door skin. You will find that 10kg is a fair bit of weight and would be enough to support a camp stove with pot and a couple of six packs."
••I've asked to be invoiced for two of them since shipping was only $30 more for the second one.
msgs350: I'll split the difference with you at $70 for shipping if interested when I get it. I know I can easily sell this on CL if you decide to pass.
EDIT: Actually shipping for each would be around $65/each at current exchange rate. This puts shipped cost around $256 USD/each.
PM'd you. This would make a great changing table for my son..haha. I like it because it seems like its the easier to clean out of the ones i've seen and i think it looks best. Going to work great for tailgating at Seahawks' Games!
I emailed vendor to possibly reach out to Mule Expedition Outfitters about possibly become a US reseller.
Now I'm thinking of getting one too. The last time I was out, I had to make coffee and ramen noodle on the ground LOL
front runner makes one for a jeep, i bet there is a way to rig it up in the GX. its 1/3rd the price of the kaon and honestly, looks much better and much better build.
https://www.frontrunneroutfitters.co...able-mk11.html
Consists of:
1 x Table Assembly
Installation Hardware
Fitting Instructions
Materials used:
Black powder coated steel
Stainless steel cables
Laminated plywood
Product Dimensions:
Closed Dimensions:
655mm (25.8") L x 361mm (14.2") H x 42mm (1.7") W
Fully Opened Dimensions:
1095mm (43") L x 338mm (13.3") W x 361mm (14.2") H
Weight:
8.3kg (18.3lbs)
Load Rating:
40kg (88.2lbs)
Consists of:
1 x Table Assembly
Materials used:
Laminated plywood
Product Dimensions:
Closed Dimensions:
Weight:
8.3kg (18.3lbs)
Load Rating:
40kg (88.2lbs)
