View Poll Results: Does your GX460 Lean?
Yes: Low on the passenger side
107
57.84%
Yes: Low on the driver side
19
10.27%
No, I've measured on a flat grade and it's even
59
31.89%
Voters: 185. You may not vote on this poll
#KDSS #Lean
Old Mar 24, 2024 | 05:51 PM
  #376
glamglam's Avatar
glamglam
Originally Posted by BillK01
Driver side rear fender well measurement is exactly 1” higher than passenger side rear in same measurement location. 36” vs 35”
I would leave it alone. You can’t really tell that the driver’s side is higher than the passenger side.
Old Mar 25, 2024 | 12:24 PM
  #377
ASE's Avatar
ASE
Definitely higher ... but no Driver ? Put someone in the driver's seat and remeasure ... given probably 85++% of drivers are riding solo ...
Old Mar 25, 2024 | 02:39 PM
  #378
John00's Avatar
John00
if you jack up the rear on the low side and the front looks better, then you could consider to adjust the height sensor linkage and then readjust the headlight.
somewhat of a workaround and might not be ideal for some people.
Old May 18, 2024 | 12:56 PM
  #379
oaklandgx's Avatar
oaklandgx
1st Gear
Default 2014 GX460 pulling to the right, wheel wells uneven?
I've had a 2014 gx premium (no KDSS) for a few years now, and it's always pulled a bit to the right on both local roads and highways. i understand that roads have a crown that can cause this to some extent for all cars but it has just seemed a bit more extreme for this car than others i've driven. could be just down to how tall the gx is, but i finally took some measurements today and wanted to see if others who know much more about these cars can tell me if these are normal.
i found a fairly level parking lot with a half tank of gas and put a 4 foot level on the rear bumper, which showed the driver's side of the car is a bit higher than the passenger side. went around and also measured the distance from the ground to the top of each wheel well and got about 1" higher on the driverside wheel wells than the passenger side (35.25" front driver, 36.5" rear driver, 34.25" front passenger, 35.5" rear passenger). so definitely seems like there is a lean to the right, which seems consistent with how the car drives.
i also figured the gas tank is on the drivers side, so just in case i went and filled up to make sure that wasn't causing any imbalance. the rear bumper definitely evened out a bit and the rear driver wheel well might have dropped a half inch (which i think makes sense, i think the tank is right there). but still the same imbalance in the front as far as i could tell.
do folks know if there's a normal tolerance for suspension heights between the two sides of the car? is 1" something that could cause a noticeable pull when driving?
Old May 18, 2024 | 02:02 PM
  #380
Acrad's Avatar
Acrad
Just for clarification “all” GX 460s have KDSS… you are probably thinking about the AVS/RAHC which is the adjustable shocks and rear air bags.
Old May 18, 2024 | 06:51 PM
  #381
mike202's Avatar
mike202
The lean and pull are two separate issues. Lexus states a max difference of 20mm left/right difference for the lean. If more than that then Lexus TSB L-SB-0015-21 provides a solution which is to replace the left front spring with a new p/n.
On the pull, it is most likely the front end alignment and there has been a lot of discussion here in the past on that topic. If you do replace the spring, the front end will need to be realigned anyway so you will take of both at the same time.
BlairC
GX - 1st Gen (2003-2009)
Sep 17, 2012 04:02 PM
dinardalvi
GX - 2nd Gen (2010-2023)
21
Oct 25, 2011 09:57 AM
Aterrex
Sep 17, 2007 04:06 PM
AlfsGX
Apr 30, 2006 03:13 PM
petsb10
Dec 11, 2005 08:41 PM
