Customized door setting question
Old Nov 18, 2011 | 05:52 PM
patgilm's Avatar
patgilm
Default Customized door setting question
I did a search and read the manual but I can't seem to figure it out. Is there a way to unlock all of the doors by pushing the unlock button on the key fob once? I see in the manual it can be done I think by turning "remote 2 - press unlock" on in the car settings but it doesn't seem to work. Also am I reading correctly that there are no door unlock sensors on the rear doors? With my LS and my old IS I could touch the rear doors and all of the doors would unlock but this can't be done on the GX?
Old Nov 18, 2011 | 10:51 PM
akfd's Avatar
akfd
If you go into customized settings in the nav system there should be a setting called "select doors to unlock" that's where you can change whether to unlock all the doors with one or two pushes of the button on your key fob.
Only the front door latches have the lock/unlock senor; the rear doors have no sensors.
Old Nov 19, 2011 | 05:47 AM
patgilm's Avatar
patgilm
Thanks. It works now. I'm just stupid.
My LS has the lock/unlock sensors on the rear doors and i think my old IS did as well so I could touch the rear handles and all of the doors would unlock. Bummer this one doesn't have that feature since I have two little kids and those are the first doors I typically touch.
Old Nov 20, 2011 | 05:13 PM
wannaGX's Avatar
wannaGX
I had the same question/request for the same reason. I had them set it so all doors would unlock when I touched the front door. Now I'm in the habit of touching the front door and then just opening the back door. You get used to it and it works fine. Enjoy your GX!
RamshakleZ
Mar 5, 2022 07:06 PM
YWW
RX - 4th Gen (2016-2022)
Sep 30, 2018 01:11 PM
austinav
Jul 8, 2014 07:39 PM
SmokeyGS
Jun 4, 2008 07:57 PM
nhey
Feb 26, 2007 07:11 AM
